Need help confirm help\relays for tow hitch
Old 04-08-12 | 07:31 PM
kphu's Avatar
kphu
Question Need help confirm help\relays for tow hitch
I finally got around to installing the tow hitch connector and relay\fuses today.
I recall reading that I require 2 but in the engine compartment there was only 1 spot that said towing? Can someone look at the attached picture and confirm if the position that is marked battery (according to the cover) should also have a relay?
Also, the green relay in the back, i only saw 1 connector that wasn't used when I first pryed the cover open. Can someone confirm that is the right connector?
Thanks! Ken
Attached Thumbnails Need help confirm help\relays for tow hitch-towingfuses.jpg   Need help confirm help\relays for tow hitch-greenrelayinstalled.jpg
Old 04-09-12 | 12:36 PM
RCsGX's Avatar
RCsGX
Mine has a relay in the spot thats empty on yours. Im not sure if its related to towing or not but from this post it seems that it is:
https://www.clublexus.com/forums/gx-...th-photos.html
Old 04-09-12 | 09:17 PM
kphu's Avatar
kphu
Thanks RCsGX, yeah, I referred to the link when I bought the stuff, but wanted to make sure. I ended up putting the 2nd relay in the empty spot this morning because the car wouldn't start. I thought it had something to do with the relays I put in. Turns out that the battery was low from leaving it on while I was working on the car last night.
Can someone confirm the back location for me?
Old 04-09-12 | 11:24 PM
mann777's Avatar
mann777
The one missing you need to instal is the Battery Charging Relay.
Old 04-10-12 | 08:28 PM
kphu's Avatar
kphu
Thank you sir...got that installed!
Old 08-03-12 | 12:23 PM
GoLakers's Avatar
GoLakers
Default Follow-up Question: Green Module at Rear
Did you end up doing anything with the green module at the rear? If it is similar to the LX, it would be identified as Towing Converter Assembly. I am wondering how this module connects to the 7 pin trailer socket.
Thanks
Somun
GX - 2nd Gen (2010-2023)
25
01-22-18 12:05 AM
abatodu
GX - 1st Gen (2003-2009)
14
12-17-14 12:12 AM
ERC4
LX - 3rd Gen (2008-2021)
07-17-11 06:26 AM
Joe67
04-23-08 05:55 PM
koolkevinj
05-03-07 02:39 PM
