spark plug gap?
Old 04-29-12, 10:20 PM
RCsGX
RCsGX's Avatar
Default spark plug gap?
I know the OEM plugs are SK20R11...does anyone know what the gaps supposed to be?
Old 04-29-12, 11:25 PM
GS4_Fiend
GS4_Fiend's Avatar
You are not required to adjust gap on iridium plugs.
Old 04-29-12, 11:38 PM
RCsGX
RCsGX's Avatar
Ive had iridium plugs before and the gaps were different on a few of the plugs. I just want to know what the gap should be. Do you know what it is?
Old 04-30-12, 01:54 AM
mann777
mann777's Avatar
Here is the info - On Denso Iridium Extra Long Life Iridium Plug
14mm Thread Size,
19mm (3/4") Reach
, 5/8" (16mm) Hex Size,
Gasket Seat, Resistor,
Solid Terminal Nut, 0.7mm Fine Wire Iridium-Tipped Center Electrode,
Platinum Tipped Ground Electrode,
043" (1.1mm) Gap,
Heat Range 20
Old 04-30-12, 08:33 AM
RCsGX
RCsGX's Avatar
I know the specs. Im curious what Lexus says the gap should be.
Old 04-30-12, 09:44 AM
BlairC
BlairC's Avatar
without access to a service manual... I am going to venture to guess the de facto gap is 0.44 as irdium is spec'd and by its nature it cannot be gapped.
Old 04-30-12, 10:20 AM
ROK
ROK's Avatar
Thanks for bringing up the subject of plugs. Do you guys typically swap them out at the 100K recommended service interval IIRC?
Old 04-30-12, 11:01 AM
RCsGX
RCsGX's Avatar
Iridium plugs can be gapped, I had to gap 2 of them on my CTS-V.
Lexus says to change them at 120K service but it cant hurt to change them at 100K.
Old 04-30-12, 11:21 AM
RCsGX
RCsGX's Avatar
With my Tundras, there was a site that had the online service manuals for free, cant find them for the GX. Has anyone here tried https://techinfo.toyota.com/techInfo....toyota.com%2F
Old 04-30-12, 01:05 PM
plunger
plunger's Avatar
Your owners manual has the answer
Old 04-30-12, 02:35 PM
RCsGX
RCsGX's Avatar
Thanks...I wasnt around my manual to check. I thought members wouldve known...guess Im use to Tundras where guys like to wrench on their rides.
Old 04-30-12, 03:11 PM
plunger
plunger's Avatar
Get yourself an AllData subscription if you like wrenching on your own rig. Pays for itself after a repair or a maintenance job.
www.alldatadiy.com
Old 04-30-12, 08:26 PM
mann777
mann777's Avatar
It is very rare that Lexus amends the OEM specs, as far as iti goes to my knowledge. Even if it is maybe a negligle difference.( + / -).
Are you looking to replace or adjust the gap to the existing one, And if so what is your current mileage.
Old 04-30-12, 11:02 PM
GS4_Fiend
GS4_Fiend's Avatar
Like I said.. Iridium plugs you dont gap them regardless. They are not regular plugs. Why you want to gap them anyways?
Old 05-31-12, 06:32 PM
DallasSC
DallasSC's Avatar
I just put in a set of NGK Iridium IX plugs along with NGK wires and I now have a pulsing idle and a flashing CEL.
My 1996 SC400 is now sluggish when accelerating and just doesn't feel like it has full power. I bought the plugs that were spec'd for my car and did not gap them.
Quick Reply: spark plug gap?
