Fault codes P0037 and P0057
Hi
Does anyone know exactly what can be done regarding these faults? P0037 and P0057
Description:
Oxygen Sensor Heater Control Circuit Low (Bank 1, Sensor 2)
Oxygen Sensor Heater Control Circuit Low (Bank 2, Sensor 2)
The catalytic converters have been removed but the fault was present before that anyway. All I want is the VSC function to work again and the lights to go off.
I have heard you can put dummy sensors in. Any thoughts?
Regards
Eric
Description:
Regards
Eric
I'd start by using a multi-meter and testing the sensors (these are both post cat converter). With cats removed, even if good O2 sensors, you'll likely need at least a spacer to keep them from faulting.
Start by testing them first though...
Good luck
Good luck
Can you check the battery Volt after the start, what is the output, you should have more that 10.5, if it less, this would trigger a low voltage to the O2 Sensors. That is why you are getting the above fault. Let us know what is the result.
