Seafoam = Clean Injectors?
Old 06-03-12, 08:53 AM
TopGear300
TopGear300's Avatar
Default Seafoam = Clean Injectors?
Anyone here throw a bottle of sea foam into their GX to clean the injectors?
A buddy of mine told me to do it and he knows his stuff. Been getting poor gas mileage
Old 06-03-12, 06:39 PM
cssnms
cssnms's Avatar
Nope. I prefer Techron.
Old 06-03-12, 07:00 PM
TopGear300
TopGear300's Avatar
Is that any better than sea foam? You ever use either in your GX?
Old 06-04-12, 12:52 AM
mann777
mann777's Avatar
I use one below - trouble free. Recommended.
Old 06-04-12, 05:57 AM
BlueES
BlueES's Avatar
I just bought 3M kit to clean up but not sure will do any harms or good. It seems similar to seafoam.
http://www.amazon.com/gp/product/B003YJ47JO/ref=ox_ya_os_product http://www.amazon.com/gp/product/B003YJ47JO/ref=ox_ya_os_product
Old 06-04-12, 07:08 AM
chrisvr6
chrisvr6's Avatar
How did you choose this particular one?
Old 06-04-12, 10:07 AM
cssnms
cssnms's Avatar
Who knows... It was developed by Chevron's engineers and Chevron adds it to their fuel, albeit in lower concentrations. I just figured these guys know what they are doing.
I have been using it over the years s a preventative measure and so far I am happy with the results. More recently I noticed a modest improvement in mpg's in my GX after adding two bottles back-to-bak at around 60k mi. I use a similar product in my Yamaha outboard, it's called Yamaha Ring Free and it developed by Chevron and has a similar make-up to Techron.
Old 06-04-12, 10:25 AM
mann777
mann777's Avatar
One of the dealers quoted using this brand & sometime Wynn's at their service intervals.
Old 06-04-12, 09:14 PM
CruiserGX
CruiserGX's Avatar
Seafoam, techron or BK44, you can't go wrong with any of them. I've use Seafoam, BK44 and Techron and they seem to the same job, dealers prefer BK44.
Old 06-04-12, 09:44 PM
Trexus
Trexus's Avatar
I recommend Redline Fuel Cleaner.
http://www.oreillyauto.com/site/c/de...0404&ppt=C0126
Old 06-05-12, 06:51 AM
TopGear300
TopGear300's Avatar
Any reason you are particular to this brand Trexus?
Old 06-05-12, 12:30 PM
Booyah
Booyah's Avatar
Cause everyone has their favorite lol---My pref is Techron as stated, already Chevron uses it their gas--so a bottle or two of Techron concentrate and a fill up, your got a lethal cleaner mix
Old 06-05-12, 12:37 PM
Trexus
Trexus's Avatar
True that everyone has their favorite.
I researched and read many reviews that Redline Fuel Cleaner has a higher content of cleaning agents compared to others. Other members on this website such as lobuxracer also prefers Redline Fuel Cleaner as well.
Old 06-05-12, 06:46 PM
cssnms
cssnms's Avatar
MSDS data:
Techron Concentrate
Distillates, hydrotreated light < 50 %weight Aka: Paint thinner(oil based)
Stoddard solvent < 35 %weight Aka: dry clean solvent, white solvent
Solvent naphtha, light aromatic 5 - 10 %weight : zippo lighter fluid
Benzene, 1,2,4-trimethyl- 95-63-6 1 - 5 %weight : powerful toxic solvent
Xylene , powerful solvent
Techron is naptha and 3 kinds of benenze.
GUM OUT INJECTOR CLEANER (WINTER GRADE)
Chemical Percent
Trade secret or proprietary formula < 1 ( secret #1)
Petroleum distillate(s) (unspecified) 40-70 ( most likely paint thinner)
Detergent/Inhibitor mixture 1-10 ( secret #2 )
Isopropanol 30-50 (rubbing alcohol, GAS DRYER "CH3CHOHCH3")
I can not begin to guess why we need more alcohol when all gas has it already.
Gasoline, must contain 2% oxygen by weight, in most smog chocked areas of the USA.
Seafoam ingredients:
1 PALE OIL 4229 40-60% = A base or process oil refined until its color = yellow.
2 NAPHTHA 20 25-35% solvent powerful , common in all good injector cleaners. Zippo juice !
3 IPA 125 10-20% = Isopropyl Alcohol (rubbing alcohol), Useless in gas , cuz it already has tons.
in my opinion , putting oil into your gasoline is not too smart. Think about it?
fouls plugs, makes lots of carbon , and messes up OXy sensors. You decide.
"GM TEC" ingredients:
2-BUTOXYETHANOL, a paint and ink solvent , used even in Clorox cleaner 409
Naptha, , raises octane rating of gas, , simular to Zippo ligher fluid. Coleman camp fuel.
4-METHYL-2-PENTANOL, (aka:Methyl isobutyl carbinol) used as a lacquer paint tinner
9-OCTADECENDIC ACID.(aka:Oleic acid, found in Olive oil) ( this acid is interesting)
BG-44k: ( madly popular but little different than old Chevron Techron)
Light Aromatic Solvent Naphtha , ( Zippo lighter fluid)
1, 2, 4-Trimethylbenzene , commonly found in up to 7% by volume already in Gasoline.
Xylene ,(1,2-dimethylbenzene & 1,3-dimethylbenzene & 1,4-dimethylbenzene), xylol , powerful solvent
Cumene ,(isopropylbenzene, ) powerful solvent,raises octane of gasoline.
GUNK , RADIATOR SPECIALTY COMPANY, FUEL INJECTION AIR INTAKE CLEANER
2-Propanone 30-60 % aka: Acetone
Ethylbenzene >10 % a powerful solvent
Hydrotreated Heavy Paraffinic Distillate 1-10 % weak solvent
Methanol 1-4% , solvent.
Propane 10-30% , gas
Toluene 15-45% ,powerful solvent
Xylene (mixed isomers) 5-20%
Red Line SI-1
1-5% Alkenylamine - (a detergent ,even used sometimes,in baby shampoo)
1-10% Isoctanol - ( C8H18O , aka, 2-ethylhexan-1-ol, or Octyl alcohol)
1-10% 1,2,4 Trimethylbenzene , (C9H12 )
5-20% Aliphactic Napthta , zippo lighter fluid. , aka: white gas, low octane)
Valvoline Complete Fuel System Cleaner
52 - 62% Kersosene
28-38% Light hydrotreated petroleum distillate
6-16% Stoddard Solvent ( stoddard is the name of the man who invented dry cleaning)
Although not listed Techron also contains a very high concentration of PEA, which is a MUST IMO. Many of the others do not.
More good info on the matter from Bob Is The Oil Guy....
SUMMARY
Symptoms: Gradually increasing car hesitation, power loss, sluggish acceleration, lowered fuel economy.
Cause (probable): Dirty fuel injectors, dirty engine valves, and combustion chamber deposits
Fix: Chevron Techron Concentrate Plus (or similar known PEA-containing (polyether amine) fuel system cleaner products like Gumout Regane, Redline SI-1, Amsoil Performance Improver, and BG Products 44K)
BACKGROUND
SUMMARIZED RESEARCH
Anytime you have gas burned in your engine chambers, not all of it burns up and you’ll eventually get deposits forming on the valves, combustion chamber, and fuel injectors. Gasoline is supposed to have detergents in them to keep your engine parts clean (some top-tier gas have more detergents than the government specified amounts), but driving short distances without having your car fully warmed up can lead to faster accumulating deposits.
Although I’ve read other numerous posts, I’ve summarized a poster’s notes from PriusChat.com in what can lead to engine power loss and hesitation:
When fuel injectors get clogged, the fuel spray pattern is affected (fuel normally is “atomized” but if an injector is clogged, it can form large droplets that don’t vaporize easily), and the fuel may not completely burn once the spark plug fires or it may burn long after the optimal burn cycle has been initiated, causing an apparent loss of power. Next, the intake valves can become coated with deposits which can soak up injected gas and affect the burn cycle, and can block the flow of heat from the cylinder, again affecting the burn cycle, thereby decreasing the engine’s power and economy. As the combustion chamber accumulates sharp-edged deposits, these sites can act as nucleation sites for pre-ignition (aka “engine knock,” throwing off the car’s timing (and again, loss of power)—this can be evident in older cars that seemingly “need” premium fuel to reduce pinging.
THE APPARENT SOLUTION
A fuel system cleaner that contains PEA (polyether amine). Alternatively, you can pay your dealer for a fuel injection cleaning service (around $250). Nonetheless, I’m always the one to try a cheaper alternative before I buck up.
Chevron Techron Concentrate (32% PEA, based on an older published MSDS spec sheet--may be different now; $8 for 12oz. bottle) has been the leading fuel system cleaner since its development sometime in the 1970’s (it's also a touted leading detergent in gas, albeit in MUCH lower concentrations than the stand-alone concentrate formulation). The main active cleaning ingredient is PEA. Other known fuel system products containing PEA include the following:
* Gumout Regane (30-40% PEA content based on published MSDS data; about $5 for 12oz. bottle)
* Redline SI-1 (30-50% PEA based on MSDS data; about $9 for 15oz. bottle)
* Amsoil Performance Improver (28-37% PEA based on MSDS data; $10 for 12oz. bottle)
* BG Products 44K (unknown PEA content since they reformulated—does anyone have this data?).
Other than the active-cleaning PEA, each product has variable fillers/detergents (i.e. Gumout has kerosene, Redline seems to have an octane booster, Chevron and Amsoil have naptha among other ingredients). I’m sure that there are other PEA-containing fuel system cleaners, but the previously listed products (with the possible exception of BG 44K) are known, sure-fire products (so I can not recommend any other products). Also, as an FYI, the cheaper Chevron Fuel Injector cleaner is NOT the same as Chevron Techron Concentrate—it’s just a watered down version of it from what I’ve read.
The use of the PEA fuel system cleaners is listed as every 3,000 miles. Personally, from what I’ve read, I would use the cleaner about 2 weeks before I got an oil change, as the cleaned up deposits will wash into your oil—not necessarily a bad thing as the oil can probably absorb and neutralize the deposits, but there will be peace of mind from having clean oil in the engine. Also, I’d use the cleaner ideally when you can make longer drives in your car to allow the cleaner to do it’s job at full operating temperature.
To use the PEA fuel system cleaners, get your gas down to about ¼ tank. Put the whole bottle of PEA-containing fuel system cleaner in your tank, then fuel up to get it properly mixed. FYI, Chevron Techron Concentrate (12 oz treats up to 12 gallons), so I used two 12-oz. bottles as the GS400 has a 20 gallon tank. Follow the manufacturer instructions for the other products.
In a nut-shell use a fuel injector cleaner of your choosing, but just make sure it contains PEA.
Old 06-06-12, 08:40 AM
TopGear300
TopGear300's Avatar
Chris is the man!! Thanks for the indepth research! Haha
After reading what you have found I think I will purchase Chevron Techron Concentrate over seafoam!
GXBaron
GX - 1st Gen (2003-2009)
19
11-15-14 02:51 PM
dag8882
04-17-10 06:42 PM
tidom78
07-10-09 09:10 AM
Quick Reply: Seafoam = Clean Injectors?
