Not to take this off topic, but these wheels will go great with the 6-piston Toyota Tundra TRD calipers. I am seriously thinking about getting a pair, but i also need bigger wheels than the OEM 17". Makes the whole project too $$$.
Your right on target man, part of my wanting to get new wheels for the GX was so I could put the original wheels onto my 3rd gen 4runner to make room for a Tundra brake swap.
I had no idea there was a possibility of putting tundra brakes on the GX but I am very interested.
Do you have any more info on the tundra brake mod for the GX?
I am talking about the calipers in the picture, not the wheels. They can work with ANY wheels, as long as there is enough clearance.
There won't be enough clearance for Tundra brakes with 20" wheels. Those calipers even have different mounting points. Several guys tried this already and it didn't work.
Where are you getting your facts that Tundra brakes will work with 4th gen 4Runner or GX470?
I am getting my "facts" from some research on the ih8mud forums. People there claim to have it done with 4runners and even the GX470. I have not done it on my GX obviously.
I never said that these calipers are direct bolt-on. You may need a bracket, which is not impossible to do/find. However, the OEM (non-TRD) Tundra/Sequoia 4-pot calipers should be able to bolt on the GX just fine. So I doubt the Tundra/Sequoia with the big TRD brake package requires huge modification.
Why the 20" wheels won't clear the TRD calipers? How big are the OEM Tundra TRD package wheels? 22", 24"? Or is the wheel offset the problem? Please do share some facts/info with us since it sounds like you are very familiar with the subject.
Tundra/Sequoia brakes on GX470 (or 4th gen 4Runner) will require more modification when you think. None of the parts are direct bolt-on. The upgrade what you probably read is for 3rd gen 4Runners, which our GX470 are not, they're based on 4th gen.
Further, the benefit of the larger brakes will be minimal for GX470 and in my opinion this upgrade is not even close to being worth it.
Get a good quality discs (Brembo) and pads (Hawk, etc..) and you'll get better stopping power, if that's what you're going for.
I already have Brembo rotors and Hawk LTS pads. Truck stops well and there are no issues to report.
My concern is that things will not be so great when i start towing my boat in the mountains.
Aside from doing the Tundra brake upgrade (with some modifications), i don't know what else i can do to improve the GX brake system.
If you're doing it for braking power, you're probably wasting your time to be honest. Bigger brakes don't really give you more braking power. If you think about it, if the smaller brakes on your GX470are capable of locking up the tires (forget ABS for a moment) during a hard stop, then that means you have all the braking power you need, simply because the friction of the tires & road is the limiting factor. The only real advantage to big brakes is that they resist fade better because they dissipate more heat. So unless you're planning on running your GX470 really hard around a road course, your original brakes should perform just as well as bigger brakes, even for towing. Especially considering the fact that you already have decent rotors and pads.
I have a 2004 GX470 and I drive a lot on curvy Hwy One on the coast in Northern California.
I don't baby it around the turns and I tend to heat up my brakes on the coast and in Bay Area traffic.
When I bought the GX last year the front rotors and pads were changes out due to warped rotors and plain wear. The new OEM rotors the dealer put on warped within 3 months. I am looking for the best way to keep from warping the rotors and fading brakes. I am considering changing both front and rear rotors to slotted and/or drilled along with top quality pads.
I'd like to hear your thoughts on the best choice for my type of driving.
The Tundra brake upgrade is also a possibility but I am not sure the cost and effort is worth it.
I'd appreciate your input !
Don't waste your time. These wheels are ONLY 7 inches wide! Not sure why Toyota decided to put a 7" wide wheel on an SUV but they did. There are only 2 tires that fit the car. Going outside the vehicle tire specs, you will find that all tire makers recommend AT LEAST a 7.5 inch wheel width.
These wheels look good from the side but from the rear/front, they look like bicycle tires. They are known as pizza cutters on the 4Runner forum.
I just picked up a 2011 T4R Limited and have already ordered a new set of the 2006-2009 OEM 4Runner Limited 18 inch wheels that look a million times better and give you a wider option of tires to use.
I came across this trying to figure out if my wife's 15' 4runner LTD wheels will swap well to my 05 GX for a long trip we have coming up. I want to drive my 05 GX470 for 4x4 because the road to the cabin is just a cut going up the side of a mountain which was not fun the last time we took a 2WD in the summer but I don't wan to long distance the 35" BFG Mud Terrains I have on the it. They look like they will swap no problem and clear the calipers but I was worried about the backspacing. I am not as worried as what it will look like as long as the backspacing will clear the rotor, its just for the weekend. Can anyone confirm that? If I try it I will confirm.
15' 4R LTD 20"
05 GX Mud Terrains
As far as brakes go I was considering a big brake kit in the past but figured I would try something first and it was a great solution. In fact I am just waiting on a few pieces before I do it again, this time to my GX. Right now I tow a 6500lb boat with a lift and 35" mud terrains and the stock brakes do OK but I also drive it hard off road and I still need a little more out of them for both. what I tried in the past was the EBC stage 5 slotted, dimpled, coated rotors with yellow stuff pads and stainless brake lines on all 4 corners (also doing a FULL flush,bleed is very important). It was such an amazing improvement I never thought about doing a big brake upgrade again. I have now done that conversion twice and this will be my third. The yellow stuff make more dust but considering the the performance gains are well worth the trade-off. They are heavy rotors and I have not had a single one warp even being crazy hot and submerging in water. For the money and trouble that is what I would recommend trying first before going with a crazy swap.
The tires on the limited I think are more of a road handling and MPG selection since they are basically the soccer mom road version. The replacement selection does suck but I replaced the stock tires on my wife's 15' Ltd. with Michelin LTX premiers (crazy expensive) but they dramatically improved the ride and handling. I really didn't like riding or driving in it before that.
The 20's will fit, but they look dumb on a GX. I drove around like this for a few months last year while a set of wheels was getting refinished. They sit sunk into the wheel wells, even worse than on a 5th gen 4Runner.
