charging system warning light on?
#31
one of the problems I came across in the lexus gx is to remove the nut from the return cable and check the bolt for heat damage . if so your connect has come lost and the connection is heating up. your going to have to reconnect. if this happens when you move the connection before removing you may have a little play. the casing is plastic so it to may have been compromised. I put the same size bolt went all the way to the starter, than a (metal) washer than the connection, than enoughther washer than nut......to this day no more batt. light problem. This vehicle carries high amps so ground connects can be a majority of electric
TRENTIMUS
GS - 1st Gen (1993-1997)
01-31-19 03:41 PM
