DIY Spark Plugs 04 GX 470
#136
X2 on spark plug tube seals in the valvecover having failed on that oily cylinder. Can't say if that's related to it being loose or not though.
#137
I have done the spark plug tube seals. Totally worth paying someone else to do them - they're miserable to change.
Do the valve cover gaskets at the same time - by this time they're going to be hard as a rock. Should be a parts-cost only increase to the job.
Chip H.
Chip H.
offroad200 (02-03-21)
#139
Spark plug torque spec seems off
I recently replaced my spark plugs. Used a torque wrench for the first plug and it seemed insanely tight and didn’t feel right. I’ve read on this forum people saying torque specs between 15-21 ft- lbf
I tightened to feel on the other 7 plugs.
But ever since I’ve changed them I’ve been curios if anyone else has felt like the threads are gonna strip When they use a torque wrench and torque to 21 ft-lbf or if my torque wrench is way off.
Any feed back is appreciated and always love learning new things about my some what new to me GX470
QuinGX (05-09-22)
#141
Never use anti-seize at best it does nothing in some cases it will fuse the plugs to the head.
#142
That’s ridiculous, and blasphemous. Except for head bolts, I’ve been using anti-seize on every fastener since I started wrenching in the 1980’s. I’ve never experienced this phenomenal you speak of.
#143
NGK has some experience making spark plugs let's see that they say about it.
https://ngksparkplugs.com/en/resourc...ut-spark-plugs
You might be surprise to learn that just because something didn't happen to you doesn't mean that something is not real.
#145
I've never used a torque wrench for spark plugs, hand tight, makes sure the washer is compressed tight.
#146
usually a quarter turn after contact is the correct torque, the good news is, the next time you may have to change these plugs...you will just be looking for a plug on the side of the road to recharge.
#147
Always use a quality, calibrated torque wrench. Years ago on my first GX plug change, I went to 21 but thought that was a bit too much. This most recent change, some interwebz browsing showed 13. This equates to approximately 1/4 turn past point of contact.
