Rear subwoofer blown
It appears as if the rear subwoofer in first gen GX470 is notorious for sucking. I was looking up part replacements and to make matters worse, it's proprietary. My question: if I pull the assembly that houses the rear speaker (or woofer, not sure what it is), is it possible to just swap the speaker with an aftermarket speaker? If so, what would fit and work? I'm no audio expert but I am assuming I have to match ohms, etc. Has anyone here done this? Replaced the rear subwoofer in the first gen GX470? Halp!
I'm not sure if it matters, but do you have the Mark Levinson audio package in your truck? You might have to pull the sub assembly out, pull the actual speaker out of the box, and see if there are markings on the magnet showing what ohms the driver is, and how much room you have in there, and trying to find a replacement that way.
toyo-diy shows the sub assembly is held in with 4 bolts, the entire assembly looks to be over $400, and there is another part # which could be the speaker itself for just over $200.
yes the subwoofer is in a plastic box that you pull out to be honest dont be mad but mark levinson sucks honestly i have alpine type r speakers in the front amazing bass just from them super clean i run my bass on 3 and its perfect set up the sub woofer i put in was a kicker cvt 6 inch sub it had trouble clearing so i made the whole a little bigger
thanks. i really just wanted to find out if I could replace it with something other than OEM plus the size, etc. So a 6" sub would most likely suffice. I suppose I'll have to find a way to make it fit, thanks for your help.
Ifthe collar is torn, you could just re-trim it and keep using it. I had to do that with my fron 6x9s twice already. Like everyone else has said, the ML speakers are total junk. For some reason, they actually sound decent all together, but they are truely as cheap as you can get.
i forgot how much ohm i got i got it last year but it doesnt require major modding fairly simple and the imporvement is so much better that little sub thumps good i can put the music on high volume go across the street hear the bass and the alpine type r speakers and i dont put it that loud not even halfway its till awesome
I am very interested in upgrading my existing ML setup, especially when i hear some rattle from the front pass. door side speaker.
