Need new tires
#31
2004 G X 470 , 35,000 miles original , the tires look good was being told they will get you through another year , well being 9 year old tires , I feel I might need new tires for traveling long distances short coming .
Any suggestions on a good tire ?
quiet ride and yet traction in the snow![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
#32
What you guys are doing with tire pressure is fascinating to me. I typically keep to the door-jamb pressure. Therefore, I'm running 32psi w/my Michelin AT/2s.
Why are you guys airing them up so much? Among other things, isn't it ruining the ride?
I've heard something about LT tires needing different pressures than standard tires. Is this influencing your pressures? Thanks, I've spent most of my auto experience tinkering with sports cars. Curious about how people think about SUV/Truck tire pressures.
#34
I think we're about to go down a rabbit hole, way way off topic...
In my experience the GX is awfully far from being sporty, much less anywhere comparable in its on-road capabilities to any BMW. As a matter of fact, my GX brings out the slowness in my driving - yup, I drive my GX like a grandpa because it's not a race car. In my opinion, I appreciate mine for what it is - a plush, quiet, sorta slow, not a corner carver in a stress reducing way. I'm continually amazed by some folks on here that try to make it into a race car / truck.
@GX470fan - With your amped up tire pressure, how much difference does it make? You mention you can feel it. Describe. I get that you're ok with the trade-off in comfort, but I wonder if you are you really getting a fair trade? (Yes, this is coming from a guy that hasn't upped his psi.)
Thanks for sharing.
Thanks for sharing.
#35
Thanks for sharing.
Thanks for sharing.
- lower rolling resistance
- less effort to turn the wheel when parked
- more direct steering response
- slightly harsher ride
No surprises here. As you'd expect -- you're just stiffening the sidewalls. Given the dive my GX took gas mileage-wise when I went with the AT/2s, i'm going to stay at higher PSI for a while and see if I get some of the MPG back.
#36
I'm running my NTGs at 40lbs. too.
How much MPGs did you loose? I didn't loose any switching to mine, if I did it wasn't noticeable. I do all city driving. If I do go on the highway it's less than 2 miles just to get to the next exit. I still average between 11-12MPGs as I did when I had the chrome stock wheels.
Stock
Aftermarket
Stock
- wheel: 26.4lbs.
- tire: 38lbs.
Aftermarket
- wheel: 22lbs.
- tire: 47lbs.
#37
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Thanks for sharing.
Thanks for sharing.
