Audio/Video Interface to connect iphone 5
MML installed today. There is barely enough room to toss it in behind the top passenger side section of the hole you pull the nav unit out of. Ran the USB cable into the glovebox for easy access. It even presses the "I agree" button like its supposed to. Note on that however that the "scan" button by the cassette deck doesnt work on the 2006 nav. You have to press the virtual on-screen scan button 8 times for the settings mode.
Thanks
That said however, this Mark Levinson system has foam surround speakers so you should accept that it's just a name on typical OEM speakers. The amplifier section might be decent but the speakers are just standard in my opinion. I once helped my father replace all speakers in a nice high end car with actual kevlar core and rubber surround speakers and while there was some noticeable improvement it's still a car and unless you are stopped with the engine off you really shouldn't expect much!
I'd imagine the difference you hear between your cars is more determined by the sound stage and acoustics of the cabin.
verly6565
10-12-16 07:33 PM
steverhode
05-07-14 09:57 AM
