How to initialize Power Windows - GX after battery Replacement or Reset
Old 08-21-19, 12:00 AM
  #31
Jsanc464
Jsanc464's Avatar
Default Similar issue, but slightly different
So my ‘06 gx470 master window switch was messing up
so I bought a new one, and still my wi Dow down feature doesn’t work. I’m referring to the feature which allows you to hold the unlock button on the key fob, and it’ll open all the windows. Even when I use the actual key to try the feature they don’t open. Otherwise they work fine. Just trying to solve the issue.
Old 08-21-19, 10:30 PM
  #32
Rygar470
Rygar470's Avatar
That to me, sounds like a pairing/SW/programming issue. Meaning, if you have the Techstream software, you can go in and reprogram these features. Are you trying this with your original key, or aftermarket which was later programmed? Just thinking outloud here.
PS: I think it should be a priority for every GX/LEXUS/TOYOTA owner, to purchase the techstream software in order to do basic commands, from scanning the vehicle for codes, to programming such features as the ones I mentioned. Cheap Insurance if you ask me.
Old 02-01-24, 06:23 PM
  #33
deltron2023
3rd Gear
deltron2023's Avatar
Default Front passenger window still stuck
Originally Posted by mann777
Gents
I am seeing lot of members asking the same repeat question on the Initialization of Power Windows on GX 470 - First Gen
I thought I could give it the illustrative way , That would make it more easier to all who aren't aware.
Hope this helps.
Just replaced my battery ran through these steps. Of note prior to changing the. Artery the passenger side window could be rolled down on passenger side but had to could. It be rolled up on that side. Had to be rolled up on driver side.
now after trying to reset all my windows, My driver side window is still stuck down. I ran through the steps you gave and even unhooked my battery again and tried again to no avail. The front passenger window switch is still blinking. And now that window is stuck down. I am unable to roll the front passenger window up from the driver side panel or passenger side panel. All other windows including sunroof are working including the auto feature on all other windows. Any suggestions.
Old 02-01-24, 06:26 PM
  #34
deltron2023
3rd Gear
now after trying to reset all my windows, My driver side window is still stuck down. I ran through the steps you gave and even unhooked my battery again and tried again to no avail. The front passenger window switch is still blinking on passenger side but not at driver side master panel. And now that window is stuck down. I am unable to roll the front passenger window up from the driver side panel or passenger side panel. All other windows including sunroof are working including the auto feature on all other windows. Any suggestions.
billconn
GX - 2nd Gen (2010-2023)
11-23-18 08:12 PM
Tipler
GX - 1st Gen (2003-2009)
12
01-19-15 03:45 PM
philjri
12
05-19-14 10:19 AM
Quick Reply: How to initialize Power Windows - GX after battery Replacement or Reset
