rear ride height uneven...
Old 06-10-14, 06:51 AM
ALAN553
ALAN553's Avatar
thats it, c is the constant based on your tire selection...D is the number you want..
phamine (03-11-22)
Old 06-10-14, 09:18 AM
kidelnino
kidelnino's Avatar
I had done the same method before but it drove very bumpy and stiff. I think the D distances on my truck are not even, the right side higher than the left side 0.8" so the method above may not be applied to my truck. Right now the D on left side is 11.8" and right side is 12.6" and it drives smooth but I'm not so sure it is the same with factory drive or not.
Old 06-10-14, 12:01 PM
RCsGX
RCsGX's Avatar
My old measurements are below from when I was at the stock ride height. Both sides were maybe 10mm off from each other. I was bottoming out in the rear when going over large dips and I was almost spot on w/ Lexus specs, so the specs aren't set in stone...adjust them to your liking.
Originally Posted by RCsGX
MY MEASUREMENTS
  • 22.125" High (+ 1.375") | Per Lexus it should be 1.57"
  • 20.75" Normal Ride Height (I wish Lexus gave us the "normal" measurement)
  • 19.875" Low (- 0.875") | Per Lexus it should be 0.79"
MY MEASUREMENTS
  • C (14.875") - D (11.3125") = 3.56" | Per Lexus is should be 3.04"
  • ** I'm running 1" larger diameter tires so if you deduct .50" I'm at 3.06" which is almost exactly what it should be
Old 06-10-14, 04:49 PM
kidelnino
kidelnino's Avatar
I just measured the right side and the C-D is 70mm. Is it alright for my truck ?
Old 06-11-14, 07:26 AM
RCsGX
RCsGX's Avatar
I posted the Lexus specs right above your post. As per Lexus is should be 77.1mm, yours is 70mm, so you're lower by a 1/4". Again, if your GX rides smooth for your taste you're good, if not adjust it until you fine the ride height for a smooth ride.
Before I lifted my GX I had to raise the rear 1/2" for it to ride better than at the stock specs and as you can see my specs were almost spot on w/ Lexus'.
After I lifted my GX I'm more than an 1" taller in the rear compared to stock and it rides great.
Old 06-11-14, 07:46 AM
kidelnino
kidelnino's Avatar
Alright, I will not change it anymore. Thank you very much
Old 07-16-15, 08:15 AM
cssnms
cssnms's Avatar
Alan did you ever try adjusting the turn buckles and did that cure your problem?
My left side (driver's side) is too low. After having the air springs replaced (shocks have also been replaced) it was fine for a while, now seems to be back to riding too low.
Not sure if it's a sensor issue or if an adjustment of the turn buckle will do the trick.
How can one tell if the sensor is bad?
Old 07-16-15, 06:36 PM
ALAN553
ALAN553's Avatar
I solved all my problems. Found a 09 blizzard white with 30K heavily service by a soccer mom that never drove in the snow. Lexus ripped her off for everything possible. Detailed the truck 3 times a year. It was like new...so much for rear suspension issues for a while.
Old 07-27-21, 04:34 PM
gman71
gman71's Avatar
Default Barrel Nut Length?
I'd prefer someone put the length measurement for properly adjusted/secured barrel nut on both the driver and passenger sides.
Then I could pop out my own maladjusted barrel nut and adjust it to the correct length, lock it, and reinstall it for the proper ride height.
Anyone willing to do that? It'd eat up 15 mins of your time, but would be SO extraordinarily helpful to so many in this boat.
Old 07-30-21, 01:15 PM
captainva
captainva's Avatar
Its easier to just add washers under the brackets than to screw with the adjusters. The center to wheel arch should be between 21-22" stock
Old 07-30-21, 08:00 PM
ALAN553
ALAN553's Avatar
post number 15 and 18 gives you height specs
AVnGX
GX - 1st Gen (2003-2009)
36
09-17-18 11:03 PM
wrightbenz
12-11-13 10:05 AM
Ty419
09-27-10 02:59 PM
agood1
01-11-10 07:16 PM
VA380
Maintenance
10-08-08 06:38 AM
Quick Reply: rear ride height uneven...
