Steering wheel controls not working properly
Old 11-17-13, 03:13 PM
RCsGX
RCsGX's Avatar
Default Steering wheel controls not working properly
Since I've owned my GX my steering wheel controls only work if I turn the wheel full lock to the left or right. I had some free time today so I though I'd try and fix it. I removed the airbag and removed the steering wheel controls but didn't find anything out of the ordinary. Terminals and terminal pins looked good, the wires were firmly in their harness clips, I don't see any pinched wires, the ground wire is connected firmly between the two airbag clips and the flat ribbon cable connecting the 2 steering wheel controls together are fine.
The odd thing is the + & - cruise control wires are wired into the same master plug as the 2 steering wheel controls and it works fine so it's something w/ the 2 steering wheel control wiring. I'm at a loss, anyone have any suggestions?
EDIT:
I found several threads of other makes / models having this problem and some said it's the clock spring. Seeing as the cruise shares the same master plug as the 2 steering wheel controls it doesn't sound to me like it's the clock spring...if it was I'd have the same problem w/ the cruise control. And my horn works fine too.
Old 11-17-13, 04:34 PM
mrblister
mrblister's Avatar
EDIT:
I know in the sc430 foum a similar symptom was diagnosed as a failure of the spiral cable.
Old 11-17-13, 05:06 PM
RCsGX
RCsGX's Avatar
Yeah that's the clock spring. It may be it but since the cruise shares the same plug as the 2 steering wheel controls I don't think that's the problem since my cruise works fine.
If I find a cheap one on eBay I might buy it just to test out. I don't really care about the steering wheel controls, I've never used them in any of my cars but I was bored today and wanted to tackle a project.
nagooyin
02-05-19 12:12 PM
joe diego
Performance & Maintenance
09-08-16 08:00 AM
Boger74
02-23-13 11:03 AM
nwcn98
01-01-11 08:50 AM
Zagman91
01-17-09 02:30 PM
Quick Reply: Steering wheel controls not working properly
