Techstream
Old 01-19-14, 06:08 PM
  #31
lesz
lesz's Avatar
Received 1,014 Likes on 693 Posts
Originally Posted by cssnms
Can you use it so the Nav allows DVD's to play in motion? What about some of the other Nav settings that cannot be used while my truck is in motion?
I've only had mine for a couple of days, and, considering that it has been about 0-10 degrees outside and that we've had lots of snow, I haven't been inclined to spend much time going out to and sitting in the cold garage to fully explore what you can and cannot do, but I don't believe that there is ability to set the navigation system to play DVDs or do much else while the vehicle is in motion. Basically, it seems to allow you to change the same custom settings that otherwise had to be changed by the dealer, such as the sensitivity of the auto headlights. In the original post for this thread, there is a list of categories of potential changes that are available, but, if you click on many of them, there are no changes available within the category. For example, one of the categories is "seat", but, if you click on "seat", you see that there are no changeable settings for the seat.
Old 01-21-14, 12:51 PM
  #32
MidniteGX
MidniteGX's Avatar
Is it possible to program new keys and register TPMS sensors with this software?
Old 01-21-14, 12:52 PM
  #33
gxman1
gxman1's Avatar
I programmed my 2 keys with techstream,
Old 01-21-14, 12:56 PM
  #34
Crispy3M
Crispy3M's Avatar
Yes.......
Old 03-31-14, 07:55 PM
  #35
Sethro
Sethro's Avatar
i just got a windows Vista HP, will that computer work?
Thanks
Seth
Old 04-01-14, 08:32 AM
  #36
Nothnghead
Nothnghead's Avatar
Thanks
Seth
I don't know about Vista but I put Win7 on mine and had to make sure it was the 32-bit version.
Old 04-01-14, 12:40 PM
  #37
shadowmite
shadowmite's Avatar
The 64 bit version works just fine, just follow the installation tutorial. Stop telling people 32-bit only!
Instructions to install techstream on Windows 7/8 64-bit (Pretty easy, if you have a problem with this procedure you shouldn't be doing your own car-work in the first place!):
http://www.toyota-4runner.org/genera...-8-64-bit.html
My mod's were:
1) Turn off DRL's
2) Turn off steering wheel retract/extend
3) Make all doors lock/unlock with one remote press
Going to program a spare key tomorrow.
Old 04-01-14, 01:50 PM
  #38
IanB2
IanB2's Avatar
My mod's were:
1) Turn off DRL's
Really good to hear this works on Win7/8 64-bit, might have to pick one of these up!
Old 04-01-14, 03:00 PM
  #39
burny
burny's Avatar
Ole Shadowmite is a hard animal, lmao
Old 04-01-14, 06:40 PM
  #40
Nothnghead
Nothnghead's Avatar
My mod's were:
1) Turn off DRL's
I take it back :-)
Old 04-03-14, 04:54 PM
  #41
lesz
lesz's Avatar
Just an FYI.
Per a thread on the ES model forum, there is an Android app available (Carista) that will essentially do what TechStream does. It allows for reading codes, clearing codes, making changes in customized settings, etc. According to the app developer, the current version will work with Generation 2 GX vehicles, but he is working on a version that will be compatible with our Generation 1 GX vehicles. The app costs $10, and using it requires an OBD Bluetooth interface, which can be purchased on Amazon for about $10. If/when the version that is compatible with the Generation 1 GX becomes available, it should be an attractive alternative to using TechStream. The total cost of the app and interface is only $20. It doesn't require installing software and drivers on a laptop, and it doesn't require hauling the laptop out to the vehicle.
chlngr
SC- 1st Gen (1992-2000)
04-09-19 11:22 AM
929rider
02-19-13 01:06 PM
melemiller
RX - 1st Gen (1999-2003)
06-29-10 11:09 AM
zudo
07-24-07 09:02 AM
cephraim
10-04-02 07:29 PM
Quick Reply: Techstream
