Back up light, plastic cover removal
Old 12-19-13, 07:33 AM
skifanatic
skifanatic's Avatar
Default Back up light, plastic cover removal
Noticed that my drivers side back up plastic cover is cracked with a small hole in the top.
Anyone know how to remove this piece?
Would like to RTV the damaged area to seal it but I need to remove it to make the repair.
I've pulled some of the inner plastic on the door but can't get at the back up plastic cover.
Let me know if you have done this and how
Any directions would be appreciated.
Old 12-19-13, 08:38 AM
mrblister
mrblister's Avatar
You have to pull the door trim and then pop all of the clips. There is a DIY on the forum. Search you will find it. I did it and its a pain to remove the back up light assemble even after you get the panel off. I had to replace the lens it was to badly cracked and was leaking
daryltrinh
06-25-23 03:26 PM
tsxnbp
06-19-15 04:25 PM
mbz560
10-29-12 08:55 PM
PlatinumIS
12-25-09 05:14 PM
Quick Reply: Back up light, plastic cover removal
