Does anyone have an Odyssey Battery in their GX?
I am considering getting an Odessey battery for the GX. There has been more than one occassion where the GX has sat for a period (esp when it's cold out) and not had enough juice to turn the starter over. In fact it happened again this morning.
Is anyone running one of these batteries? How has it performed?
What qualifies Interstate as being the "best" or better than an Odessey? By most accounts (that I have researched) Odessey batteries are rated at or near the top of the heap in terms of quality performance batteries.
Some specs on some batteries for those looking intn premium
batteries.
Odessey
BCI Group Size 27F
Pulse (5-second) Hot Cranking Amps (PHCA) 1500
Cold Cranking Amps (CCA) 850
20Hr Nominal Capacity (Ah) 68
Reserve Capacity Minutes 135
Dimensions L x W x H - Inches 10.85 x 6.76 x 7.82
Metric Dimensions L x W x H - mm 275.6 x 171.7 x 198.6
Weight (lbs) 49.5
Weight (kg) 22.4
DESIGN LIFE 8-12 years (Float) @ 25˚ C (77˚ F) 5 years
SERVICE LIFE 3 to 10 years
Interstate
Mega-Tron Plus
30 Month Free Replacement
Six YearPerformance Warranty
710 CCA (Cold Cranking Amps)
Part # MTP-27F
Optima Deep Cycle (Yellow Top)
Cold Cranking Amps: 830
Cranking Amps: 1025
Nominal Voltage: 12 volts
Open Circuit Voltage (fully charged):13.1 volts
Internal Resistance (fully charged): 0.0025 ohms
Capacity: 66 Ah (C/20)
Reserve Capacity:
BCI: 140 minutes (25 amp discharge, 80°F (26.7°C), to 10.5 volts cut-off)
Optima (Red Top)
Cold Cranking Amps: 720
Cranking Amps: 910
Open Circuit Voltage (fully charged): 12.8 volts
Internal Resistance (fully charged): 0.0030 ohms
Capacity: 44 Ah (C/20)
Reserve Capacity: BCI: 100 minutes (25 amp discharge, 80°F (26.7°C), to 10.5 volts cut-off)
batteries.
Odessey
BCI Group Size 27F
Weight (lbs) 49.5
Weight (kg) 22.4
Interstate
Mega-Tron Plus
Part # MTP-27F
Cranking Amps: 1025
Reserve Capacity:
Optima (Red Top)
Cranking Amps: 910
FYI... The Sears Diehard Platinum is a rebadged Odyssey.
Email from company...
David:
That is a very astute observation. We private label the Sears DieHard
Platinum batteries and they are rebadged Odyssey batteries.
Thanks.
Kalyan Jana
Development Support Manager - Specialty Markets
Desk: (660) 429-7505
Cell: (816) 308-1543
Fax: (660) 429-1758
www.enersys.com
-----Original Message-----
Sent: Monday, April 28, 2008 6:42 AM
To: Jana, Kalyan
Subject: FW: Website Visitor Comments / Inquiry
From: db@ilikecoconuts.com [mailto:db@ilikecoconuts.com]
Sent: Friday, April 25, 2008 6:57 PM
To: Niethammer, Carlene
Subject: Website Visitor Comments / Inquiry
Comments
Hello,
I recently discovered the Sears DieHard Platinum line of batteries and I
noticed they look identical to the Odyssey line. Is there a difference
between the two?
Thanks for your time.
David Baker
David:
Thanks.
Kalyan Jana
Fax: (660) 429-1758
www.enersys.com
To: Jana, Kalyan
Comments
Hello,
between the two?
David Baker
David:
Thanks.
Kalyan Jana
Fax: (660) 429-1758
www.enersys.com
To: Jana, Kalyan
Comments
Hello,
between the two?
David Baker
David:
Thanks.
Kalyan Jana
Fax: (660) 429-1758
www.enersys.com
To: Jana, Kalyan
Comments
Hello,
between the two?
David Baker
Got it installed this morning and it fits great. First impression on start-up, the starter turns SOooo much quicker, the engine just fires up almost instantaneously. So far so good, now let's see how long it lasts or if it ever discharges enough to not turn the starter. Fingers crossed....
