White Tux Edition GX
Black Plasti-dipping the grill today.
Reviving the thread for a question.
What tape can I use the reattach the 'L' ? I have 3M double sided tape, but it is thicker than I'd like.
Any thin tape out there?
4 coats so far.....
4 coats so far.....
I like the look and will follow suit ... definitely post pics when installed.
When I removed it I used a heat gun so the adhesive was able to stick back onto the grill "L" spot. I also put 2 little dabs of silicone on the back of the chrome "L" tabs just to be safe.
Word of caution on removing the grill. One of the mounting tabs broke off because the nut/bolt were seized. Another tab was cracked (fixed that). 6 out of 7 tabs are still good so no big deal. Cheap hardware and cheap plastic. Be careful!
Thanks!
One of my tabs was cracked too. I fixed it with JB weld and I added it to all of the tabs to make sure they don't crack down the road. Make sure not to over tighten the bolts when putting the grill back on.
I took all the glue off. Will use silicone to reattach.
J-B Weld is a great idea!
Am going to put some rubber washers under the nuts and anti-seize on the threads. And yes, tighten VERY carefully. Couldn't believe the hood latch assembly screws on to the plastic grill. LOL! That's the area where mine is cracked. I imbedded a dime in Permatex Ultra Black to reinforce that fastener crack.
I love those wheels. Where did you find them?
I have the same color, but all stock- no lift. Still debating if I want to lift my DD.
How do you like the vent shades? Are they weathertech? Do you notice any increase in wind noise?
