90K + Service Quote
90K + Service Quote
Local Toyota dealer quoted ~$1,300+tax for the full 90K service including the water pump, front & rear differential and transfer case fluids. I provided them with service list from the Lexus website. I want to include the extra fluids because I tow a boat.
Comments on the price?
Does it also include the timing belt? At 90K Lexus recommends replacing it but when I asked about the timing belt being included in the 90K they said it wasn't.
If it is included in that price, that's a fair price considering it's at Lexus. If it's not definitely have them replace your timing belt since they're replacing your water pump.
Coming from a Lexus dealer that does not sound all that unreasonable esp considering it includes replacing the diff/transfer case fluids.
Does the list include replacing the serpentine belt?
And since you tow, I would highly recommend adding replacing the transmission fluid to the list if you have not done-so recently. Toyota even recommends this procedure in the manual if you tow. I had mine done at around 60k miles.
Take your list to your Toyota dealer and see what they will do the job for.
It's still a lot of $$$ but it will set the stage for keeping it in decent shape for years to come. I know I'll need shocks and my passenger CV axle is starting to leak (already did the driver's side). I'm the second owner of my GX but I've had it 4.5 years. It does everything I need it to do and it still looks good (except for the f'd up dash!).
The OEM uspension is a whole 'nother money pit!
You could certainly probably get it done for less elsewhere, but that price sounds fair and you know Toyota will get it done right.
How did you make out with the Tacoma search?
It's tough thinking I will probably put close to $3K into it in the near future if I do the 90K, shocks, CV axle, etc. In my mind it is the same as 7 payments or so. Since I'll be spending some coin, I'll bring up the dash issue since they are dealing with the same problem with 4-runners.
TheGoodGuy
10-26-16 06:52 AM
mhoepfin
04-16-09 12:58 PM
