Please HELP! ABS, VSC, TRAC. Codes: C0200 c0205 c1223
Old 03-03-14, 05:36 PM
Globalinx
Globalinx's Avatar
Default Please HELP! ABS, VSC, TRAC. Codes: C0200 c0205 c1223
Hi all, please help if you guys can.
i have an 03 GX. After years of abuse something had to give. It started as ABS, TRAC, VSC lights coming on and off here and there, usually reset by a vehicle restart. But now they r lit constantly. I took the car to a shop, they said that there is a damage to left CV shaft and a Swaybar link and should be replaced. Could someone tell me if those codes C0200 c0205 c1223 may relate to the mechanical issue i was told about. Or what they might be. Thank you fellas
Old 03-03-14, 05:52 PM
lesz
lesz's Avatar
Received 1,014 Likes on 693 Posts
A Google search yielded this.
http://engine-codes.com/c0200_lexus.html
Old 03-03-14, 06:01 PM
RCsGX
RCsGX's Avatar
C0200: Right front wheel speed sensor signal malfunction
  • Right front speed sensor
  • Each speed sensor circuit
  • Speed sensor rotor
  • Sensor installation
  • Master cylinder solenoid (Skid control ECU)
C0205: Left front wheel speed sensor signal malfunction
  • Left front speed sensor
C1223: Malfunction in ABS control system
  • ABS control system
Old 03-03-14, 06:21 PM
Globalinx
Globalinx's Avatar
thanks guys. now what do i do with that? Its hard to believe that all 3 things went at the same time?
Old 03-03-14, 10:54 PM
RCsGX
RCsGX's Avatar
Either you need front speed sensors or master cylinder solenoids.
http://lexus.sewellparts.com/oem-cat...X470-2005.html
Right front part number: 8954204020 (89542 in the diagram above)
Left front part number: 8954304020 (89543 in the diagram above)
As far as the C1223 code, it could've popped up due to the bad speed sensors or it could be due to bad master cylinder solenoids. I'd take it to Lexus / Toyota and have them take a look.
Old 03-04-14, 08:36 AM
Globalinx
Globalinx's Avatar
now apparently the car needs left front speed sensor which has bad reading and a steering positioning sensor which has no reading....
Old 03-04-14, 12:59 PM
tz693
tz693's Avatar
Before you go further, you may want to check the fuse (ABS?) first.
Old 03-04-14, 01:17 PM
chiph9
chiph9's Avatar
How old is your battery? Low voltage can cause lots of strange electrical issues in modern cars.
Chip H.
Maca1281
04-22-24 01:54 PM
Jesterking
01-16-19 04:57 PM
Crobe
05-28-18 08:48 AM
Rbliss
07-12-15 09:00 PM
rstep1
06-10-07 08:17 PM
Quick Reply: Please HELP! ABS, VSC, TRAC. Codes: C0200 c0205 c1223
