2013 FJcruiser/4runner wheels with 265/70/17 Duratrac's
Rather than hijack the other wheel/tire threads, I thought I'd post my own findings. I picked up these wheels from a 2013 FJcruiser but I believe they are the same on some of the 5th Gen 4runners:
I'm not sure what the off-set is but they look like they'll mostly keep gravel off my paint:
They ride much more firm than the bridgestone duelers that were on there and they do hum a bit. I got the light truck "E" rated for more durability but they also make a "C" rated that would be a bit softer. I plan on taking this on a lot of trails and so want a stiff side wall for running low PSI. I'm not sure if my rationale is sound but that's what I've done.
They do rub at the very bottom of the front inner fender liner at full lock. I'm not sure why Toyota designed the liner this way but a heat gun will fix this:
I'm sure I'll get more rubbing when I really stuff that tire up in the wheel well. At least they're not hitting any metal.
Those look great! I have the same size Duratracs but in C-load on my GX, love them.
Looks great, I am in need of new tires and there are lots of wheels/tires off new FJ and 4runners for sale out here, does anyone know which 4th gen fit correctly or the closest? Most are 265/70/17 like you used but seems to be a bit tall?
I cant find a conversion and TRD looks like a good choice too
Thanks
Thanks
Thanks
Thanks
Thanks
Thanks
4runner over FJ wheels is a better choice then...for more of a OEM fit, what about centercaps, do they interchange?
What about tacoma trd rims?
.Thanks guys!
.Thanks guys!
MIGS
SC- 1st Gen (1992-2000)
72
10-23-11 08:03 AM
