Check engine light with VSC Track/Off indicator
Old 01-13-15, 08:39 AM
fantic
fantic's Avatar
Sue1900. I fixed mine for about $100.00. Search my threads. Need any help just ask.
Old 03-16-16, 03:37 PM
Savnout
Savnout's Avatar
Originally Posted by T4Fun
are you original owner. if not, is there one of those insurance trackers underneath.
also, wrong forum
Can you elaborate on this? I have a 2004 RX 330 just purchased from a crappy used car dealer and only code just popped up a month after getting it home is C1201.
Under dash looks crowded... Like something was put up in there.
SAV
Old 03-17-16, 05:51 AM
chiph9
chiph9's Avatar
Look for the diagnostic connector and see if anything is plugged into it.
If the wiring is a mess, it may have had an alarm or payment tracker installed. Sometimes the "buy here pay here" dealers install them to make sure payments get made. And when it's paid-for, the don't remove the alarms - they just disable them.
Chip H.
Old 03-17-16, 09:37 AM
sheikhmax
sheikhmax's Avatar
Default May Be a Faulty Gas Cap
I have seen those Christmas lights on the Dash soon after i bought my 08 . Well a replacement gas cap fixed it. Is your gas cap loose, mine was worn and wouldn't close tightly. I installed a new Gas Cap, disconnected the negative battery terminal. Reconnected and started the car...
It might be worth a try.
Old 03-17-16, 12:36 PM
john689089
john689089's Avatar
Monday69 - check your gas fill cap. If it's loose from your last fill up or the gasket is worn, those lights will come on. You may need a new gas cap - $30 from dealer. After you tighten the old gas cap or replace it with a new one, you need 5 or 6 cold starts before the lights will stay off.
Old 03-21-16, 07:58 AM
Savnout
Savnout's Avatar
Chip H.
Thanks chip. Light went out, might have been gas cap loose. Weird thing was with Techstream, only code I was getting was C1201...no other, and the eng. Mgt code is way too vague to even start guessing. Yes, there is a GPS unit tied in up there...I'm posting a pic...notice the lil box with extra cable tied up. Oh, well...price I pay for recession of 09...thanks again for the help.
Sav
Little black box with extra cable...GPS install by bank.
Old 03-21-16, 01:28 PM
chiph9
chiph9's Avatar
Yeah, those things suck. I would leave it in place until it starts giving you problems. Trying to re-splice the wires they cut could just make reliability worse.
Chip H.
ibgolfn
GX - 1st Gen (2003-2009)
43
04-04-21 08:58 AM
brandon17
Maintenance
07-03-18 02:15 AM
larryd2609
RX - 1st Gen (1999-2003)
12-20-11 01:46 PM
Icy350
05-21-11 04:32 AM
chip99
07-31-06 08:02 AM
Quick Reply: Check engine light with VSC Track/Off indicator
