Mileage and How Long You Anticipate to Keep
Old 09-19-15, 05:32 PM
  #61
Randy20g
Randy20g's Avatar
Not only didn't it leak....but the bearing felt fine. So did all the pulleys. The only part that showed wear....was the belt itself.
Old 09-19-15, 06:03 PM
  #62
SC3coupe
SC3coupe's Avatar
Originally Posted by Randy20g
Not only didn't it leak....but the bearing felt fine. So did all the pulleys. The only part that showed wear....was the best itself.
May I ask what is your philosophy of not changing the timing belt until now, obviously you won and saved a bit of money there.
When I drive mine it is under 2000 rpm on the free way and 1200 creeping around town.
I wouldn't try that mileage on a sports oriented engine with higher rpm though
Old 09-19-15, 06:24 PM
  #63
Randy20g
Randy20g's Avatar
This truck is driven and not babied. It receives the maintenance it requires and is well cared for. As for the belt, I knew these belts could go a long way. I simply procrastinated doing the job.
As for a "sports oriented high mileage engine", I come from a long Mitsubishi background working on the 2.0l turbo 4g63 enigine. I have gone well over 100k on belts on that interference engine which spins at 7k all day long.
I did have a belt break on a 4AGE engine in an MR2, but that's a clearance engine and there was no issue after belt replacement.
Old 09-20-15, 07:08 PM
  #64
HaywardLex
HaywardLex's Avatar
Glad to hear these GX's will run to 200K. I recently bought a 2005 with 130K on it (I got all the maint. records that the previous owner had) timing belt replaced at 92K. I was originally looking for a 4Runner but found the GX and liked all the creature features, and had always been told that if regular service was done they would go 200K - 250K. I have been surfing this site and really like all the helpful information - I'm looking forward to seeing how this thing holds up. I have a 2004 Honda Pilot with 135K trouble free miles and I've had really poor luck with domestics ( except for a 1986 Suburban Diesel that I ran to 285K). If this Lexus holds up I'm never again going to buy a domestic.
Old 09-21-15, 08:25 AM
  #65
ScatAdams
ScatAdams's Avatar
^^ They will go a lot further than 200-250k just keep up with the maintenance!
150k on mine, plan on keeping her for a long time!
Old 09-21-15, 10:24 AM
  #66
Ali SC3
Ali SC3's Avatar
250k and counting...
Old 10-04-15, 04:18 PM
  #67
Morphyne
Morphyne's Avatar
Originally Posted by burny
09 with 31,000 on it. probably keep a few more years.
My 07 4runner has 155k on it and it will be going to my son in approx 4 years. My wife's 05 gx470 has 97.5k on it and at that time it will become mine. Plan on keeping these til at last 200k.
Old 10-07-15, 09:06 AM
  #68
Aramis
Aramis's Avatar
Just hit 250k miles on mine and plan to keep until i hit 300k!
Old 10-08-15, 06:21 PM
  #69
Randy20g
Randy20g's Avatar
Default Valve Cover Gasket
Ok guys...next project....371k miles
I had a small weep from the passenger valve cover gasket towards the rear.
Job took 1 hour to complete, and was painless.
Pictures reflect the condition of the cover and cams as seen upon removal of the cover.
FYI...truck is being run on Pennzoil Ultra 5-30.
Attached Thumbnails Mileage and How Long You Anticipate to Keep-gx470-vc3.jpg
Old 10-08-15, 06:23 PM
  #70
Randy20g
Randy20g's Avatar
shot of the cams...
Attached Thumbnails Mileage and How Long You Anticipate to Keep-gx470-vc2.jpg
Old 10-08-15, 06:33 PM
  #71
SC3coupe
SC3coupe's Avatar
Looks really good
Only first time valve cover gasket?
My 2jz was weeping from many places at 130k
And it is non turbo ..
Old 06-21-16, 07:33 AM
  #72
Randy20g
Randy20g's Avatar
Default next milestone reached
there goes another 100k
Old 06-21-16, 07:58 AM
  #73
SkeetShoot
SkeetShoot's Avatar
Currently at 130K... Plan to keep until it blows up.
Old 06-21-16, 08:02 AM
  #74
Randy20g
Randy20g's Avatar
it will rot long before that ever happens...........
Old 06-21-16, 08:37 AM
  #75
sheikhmax
sheikhmax's Avatar
Thats Amazing and Awsome.
Quick Reply: Mileage and How Long You Anticipate to Keep
