GX470 - How to replace Front Wheel Axle bearing and Seal replacement
Old 09-10-22, 04:08 PM
  #31
bijandas
3rd Gear
bijandas's Avatar
I am looking for suggestions folks. Lexus Toyota advised me to replace Front wheel axle bearing (driver side) for GX470 2008. I am at 85k miles. Questions-
1. Shall I replace the bearing assembly or just the bearing?
2. Since I am doing driver side replacement, can I go ahead do the right side as well
3. Would Lexus Toyota or AAA service center be cost effective or someone smaller but a good mechanic? Toyota is asking for $550 each side.
4. I am thinking of replacing other items too alongside since the car is approaching 90K major service i.e. water pump, belt, spark plugs, struts, mounting brackets, overhead gasket and oil seals to prevent future leaks
Thanks for your time. Please share thoughts / experience
Old 02-21-23, 06:32 PM
  #32
MulletFred
1st Gear
MulletFred's Avatar
Default Loosening Rusted / Tight hub assembly
Originally Posted by Morphyne
I put a large acorn nut between the bolt head and the spindle and as I backed out the bolts, they pushed the hub off. Saves you from having to beat/pry off the old hub and really helps break rust.
I found another similar way to remove a tight/rusted hub easily. Get the 4 bolts that hold the assembly to the truck broken loose. Put a piece of steel around 1/4" thick between the bolt and the hub and loosen the bolt a few turns, then work your way around the hub doing this. Repeat a few times until the bearing/hub assembly pops loose. No pounding, no problem.
Old 01-15-24, 02:28 PM
  #33
claybird
5th Gear
claybird's Avatar
Thanks for the help - this was much appreciated.
mstrsltr
GX - 1st Gen (2003-2009)
19
02-27-20 10:16 AM
tomclayton
03-16-17 08:53 AM
GHo23
08-23-16 03:53 PM
wsgx460
GX - 2nd Gen (2010-2023)
05-23-13 05:56 AM
Lou19
05-01-06 06:18 AM
Quick Reply: GX470 - How to replace Front Wheel Axle bearing and Seal replacement
