Where's the TPMS Reset Button?
Old 01-02-15, 08:56 AM
NTH
NTH's Avatar
Default Where's the TPMS Reset Button?
I've owned fairly recent Toyota models like 03 4runner, 04 Sienna, and 11 Sienna, and all have a TPMS reset after you adjust air pressure. I looked all over yesterday and in the manual but didn't see any mention of it. I'm certain the 2nd Set button below steering column is only to switch to a second set of wheels. Ideas?
Old 01-02-15, 09:26 AM
mrblister
mrblister's Avatar
I don't believe there is one. I have a 2004 and there is none. In fact you need the tech stream device to do it or else a trip to the dealer
Old 01-02-15, 11:33 AM
chiph9
chiph9's Avatar
If you had to add air, the TPMS will recognize that automatically.
The tech stream device is needed when you change out a sensor, like when one goes bad.
Chip H.
Old 01-02-15, 01:11 PM
NTH
NTH's Avatar
So as long as you're in a predetermined range the system will recognize that, and won't trigger the inflation symbol? Ok, that's new to me then.
I do have another noob question then. So when I replace tires at Costco, do I have to go back to the dealer for their stream device if no sensors were replaced? Thanks so much folks.
Old 01-03-15, 04:44 AM
GXallday
GXallday's Avatar
What? lol. It's a "2ND STRT" button, and it's for transmission to start in 2nd gear instead of 1st. To reduce wheel spin in snow/ice. Check inside your glove box for the reset button
Old 01-03-15, 05:31 AM
burny
burny's Avatar
^this here
Old 01-03-15, 06:43 AM
mrblister
mrblister's Avatar
2004 gx470 has the tpms tire switch under lip of drivers side dash [ allow for 2 nd set of tires to be programed ] The second start switch is a rocker switch on the dash in same general area but higher and easier to get to.
Old 01-03-15, 07:30 AM
Barnesie
Barnesie's Avatar
No need to go back to the dealer with routine tire replacement if none of the sensors are damaged. I just had my tires replaced at Costco, X Radial LT2 - the best tires IMO - same as the LTX MS2, and costco was able to "rebuild" the TPMS, which is standard practice.
Old 01-03-15, 07:43 AM
NTH
NTH's Avatar
Here's a pic of the button I was referring to, NOT the 2nd Start button. There's no button in the Gbox. Lol!
Old 01-03-15, 07:45 AM
NTH
NTH's Avatar
Thank you!
Old 01-04-15, 10:54 PM
GXallday
GXallday's Avatar
I just said to check glove box. I've owned a few cars that had the reset button placed there. My GX is an 03 so it doesn't have TPMS, so I was just saying to check it.
Old 01-05-15, 12:46 AM
kornpeef
kornpeef's Avatar
that is the tpms and a second tire set switch.
if pressed and held with car on the tire light will flash 3 times then go off. make sure its set to main. if it is set to 2nd the tire light will not go off. this model can store 2 sets of tpms sensor. one for regular tires and one for a winter set. this option was only for a couple of years though. cause no one ever bought an new set winter tires with the sensors and wanted to pay for the extra cost of programming the second set of sensors. double check the full size spare and make sure its properly inflated. people miss that all the time.
Old 01-05-15, 05:03 AM
NTH
NTH's Avatar
Oh ok
Korn- Thanks, I appreciate your informative feedback. Funny the manual made no mention of this, but again I'm not surprised. Agreed with you regarding the spare. I make a habit to check all my spares at oil changes.
gbdad
10-03-18 02:16 PM
mcamson
06-01-17 10:32 AM
doodlebug
10-28-16 10:26 PM
BillON1
RX - 3rd Gen (2010-2015)
02-03-11 11:47 AM
nicholasg
04-16-09 02:09 PM
Quick Reply: Where's the TPMS Reset Button?
