Auto windshield wiper malfunction?
Old 01-20-15, 08:40 AM
Nathan H5
Nathan H5's Avatar
Default Auto windshield wiper malfunction?
Hi all,
I searched in the forums with no luck, so I'll ask here.
My auto windshield wiper function has become real sensitive...When driving in the lightest rain or even mist, my wipers start intermittently, then go faster and faster until they are going steadily, and in medium-light rain, often go to high speed. They never did this in the past, this has recently started. I turn them off, then back on and the process repeats. The auto wiper was always wonderful in the past, but not now.
Is there some kind of adjustment for this problem? Is my windshield sensor going bad?
Thanks!
Fred
Old 01-20-15, 08:52 AM
chiph9
chiph9's Avatar
Is there a stone hit on the glass anywhere near it?
Have you applied any chemicals/solutions to the glass?
Is the sensor starting to peel off the inside of the glass?
Chip H.
Old 01-20-15, 08:56 AM
kamlung
kamlung's Avatar
just disconnect the auto sensor and you can have normal intermittent settings
Old 03-14-15, 01:38 PM
NTH
NTH's Avatar
My auto wiper is working fine but annoying at times. Disconnected the wire today to have regular intermittent function instead. easy peezy!
Old 03-15-15, 08:11 AM
99suprduty
99suprduty's Avatar
which wire is it? I assume I have to pull that cover off first?
Old 03-15-15, 04:27 PM
NTH
NTH's Avatar
After you remove the cover closest to the headliner, there's only one wire with connector present. Disconnect then replace cover.
Old 03-17-15, 01:35 PM
coloboardi
coloboardi's Avatar
Just disconnected my sensor the other week, SO MUCH better now!
Old 11-17-15, 01:19 PM
glassmanj
glassmanj's Avatar
i started looking for a fuse as my intermittents didn't work and luckily i thought to check here. simply unplugged the sensor and now they work.
one note on the windshield mount, there is a metal bracket that the plastic shell clips onto. it releases with a pull out clip on the bottom. your fingernails can flick it out of both sides. the metal bracket has to be glued to the windshield first so if yours has fallen off take the metal bracket out first and glue to windshield then as double sided tape in the center of bracket before you replace the plastic housing. then lock in place with clip.
the bummer is my wife has a 2006 RX 400h and the auto wipers on it are awesome. one thing to remember is that you can control the auto speed with the intermittent speed adjuster. it works the same way, the auto will come on quicker or slower depending on where you have the setting. so if you had it on intermittents and switched it from quick to slow and then switched back to auto, the wipers will take longer to trigger because you adjusted the speed. imho, that could be a cause of some peoples problems with the wiper consistency. maybe not.
Old 11-17-15, 02:56 PM
Ali SC3
Ali SC3's Avatar
I don't remember the stalk having an adjustment for how fast the intermittent is on my GX, it just says auto. If I understand right if you disconnect the sensor the auto turns into intermittent, but still no adjustment.
Old 11-17-15, 03:08 PM
mcomer
mcomer's Avatar
The ring that rotates adjusts the Auto feature, up is more action and down is less.
Be sure to lift the stalk to Off when going through an Auto Wash!
Old 11-18-15, 06:42 AM
chiph9
chiph9's Avatar
Hmm. I'll have to look at that. I thought it controlled the intermittent wipe interval for the rear wiper.
Chip H.
Old 11-18-15, 06:54 AM
ALAN553
ALAN553's Avatar
there is no variable intermittant for the rear, just on and occasional.
Rdoktbr
03-03-19 01:20 PM
glassmanj
GX - 1st Gen (2003-2009)
05-19-16 02:26 PM
Joebootx
12
12-25-14 06:44 PM
Bob259
CT 200h Model (2011-2017)
02-21-13 05:17 PM
garyr
04-02-09 06:24 PM
Quick Reply: Auto windshield wiper malfunction?
