Window Sweep Replacement
First off. New owner to a 2007 GX 470. Always owned 4runners but thought I would give the GX a shot. This is a very cool site! Since it is a 2007 of course things are starting to breakdown and need attention. Some of my window sweeps/dew wipes are starting to fall apart. Has anyone had to replace these? If so what did you use? I cant locate any pre-cut for the GX, I can only find generic material. Any help would be appreciated.
Is that the thing at the base of the window? If so, there is a small black screw on the inside of the door panel where the front and rear doors meet on the respective door. Unscrew that and pull toward the rear of the car while wiggling vigorously for the front.
