VSC TRAC, VSC OFF, ABS indicators HELP
Old 02-25-15, 05:54 PM
itzjake
itzjake's Avatar
Default VSC TRAC, VSC OFF, ABS indicators HELP
So a while back I blew a fusible link in my 04 GX470. Got all that fixed and all of my fuses checked and replaced along with a relay switch or two. Before this, I had no real problems and no indicators on my dash. However, after all was said and done and "fixed" I have VSC TRAC, VSC OFF, and ABS illuminated.
The dealer said that the main code is reading "left front wheel speed sensor" aka $400+ to replace. The mechanic also thinks my ABS ECU could be bad.
My point is, I didn't really have any problems before this issue with my fusible link occurred. Is there any other procedure I can try to get these to go out or reset? Replacing that wheel speed sensor, and then on to the next part, and the next, etc. would cost a fortune. Thanks in advance.
Old 02-27-15, 06:46 PM
Wahevets
Wahevets's Avatar
I had a 2006 4Runner and if I remember correctly similar indications and I tracked it down to a what I thought would be a speed sensor and told a local repar shop. It turned out to be just a brake light switch on the brake pedal. Just something to check.
King007
02-05-19 07:30 PM
SmilesHelp
09-12-18 08:16 AM
Jayd41
05-21-14 09:26 PM
ZeekGS300
07-28-10 09:35 AM
jettie1767
10-21-06 12:55 PM
Quick Reply: VSC TRAC, VSC OFF, ABS indicators HELP
