Does the Front Nav. screen play DVD movies?
Old 03-24-03, 09:41 AM
Cessna172
Cessna172's Avatar
Default Does the Front Nav. screen play DVD movies?
If you are parked will the FRONT nav. screen play DVD movies?
Thanks,
Donovan
Cessna172 is offline
Old 03-24-03, 11:13 AM
JocDoc
JocDoc's Avatar
Smile
Donovan,
There is a thread in Lexus electronics about the front nav. screen and DVD. It can be done with certain equipment. I also found it in the IS-300 section. Good luck!!
Ed
JocDoc is offline
Old 03-24-03, 11:25 AM
Cessna172
Cessna172's Avatar
Originally posted by JocDoc
Donovan,
Ed
Thanks for the reply. Yeah I did a search on the electronics page but wasn't sure is all Nav systems were the same on different models and since this is a GX470 forum I wanted first hand experience from those who have this model.
Maybe I didn't elaborate enough on the question....
Can you play DVD movies on the FRONT Nav. screen on the GX470 STOCK right off the showroom floor? Assuming of course you have the Mark Levinson/DVD Nav. option.
Thanks,
Donovan
Old 03-24-03, 11:34 AM
JocDoc
JocDoc's Avatar
Donovan,
Thanks for the clarification. I don't have the rear DVD option, but in my research on this topic, I did find a thread which suggests you can actually watch DVDs on the front screen if you have the Mark Levinson system. I believe your vehicle must be stopped, in park, and the emergency brake applied. Again, I cannot verify this in my own vehicle.
Ed
JocDoc is offline
Old 03-24-03, 11:48 AM
Knicksfan
Knicksfan's Avatar
Default Yes you can
Actually it seems only necessary to have the parking brake applied. I have shifted out of park and the movie plays until I release the brake.
Since I spend a fair amount of time sitting in my car (arrive early at client - wait in car; wife runs in to store to "pick something up - wait in car, etc.) this has turned into a major plus.
Knicksfan is offline
Old 03-24-03, 12:04 PM
Knicksfan
Knicksfan's Avatar
Default Yes you can
Old 03-24-03, 12:55 PM
Cessna172
Cessna172's Avatar
Thanks everybody for the quick responses. That is cool that you can watch DVD's. Of course I'm sure this will cause arguments w/ my S/O as I will never want to go shopping again Kidding of course but I'm sure it will be tempting.
Anyway thanks all,
Donovan
Old 03-24-03, 02:56 PM
robinzon
robinzon's Avatar
You need the REAR ENTERTAINMENT package in addition to the NAV/DVD system. As far as shifting out of park with E-brake applied, well did you try moving (yes its not great to do so with E-brake applied but still)... try it see what happens. If so that means only the E-brake wire needs to be grounded.
robinzon is offline
Old 03-24-03, 04:56 PM
Knicksfan
Knicksfan's Avatar
Default Yes I moved
I didn't move far or fast but I went into "D" and went forward and the movie still played.
Old 03-25-03, 04:20 AM
AWilmit
AWilmit's Avatar
When you start moving the front screen goes off dvd and on to NAV.
AWilmit is offline
Old 04-02-03, 04:32 PM
craigt
craigt's Avatar
I can confirm that the DVD plays on the NAV screen when parking brake is on and car is moving less than 2 MPH. If you lower the parking brake as much as you can without the DVD changing to NAV, and then drive the car, at 2MPH the NAV screen comes on.
So, who knows how to defeat this? On aftermarket DVD players with front row screen, all that is required is to ground the parking brake wire to defeat. The GX requires that as well as some speed sensor.
When you figure it out, post it here!
Craig
craigt is offline
bbqelitist
05-20-15 09:58 PM
prjctSC300
GX - 1st Gen (2003-2009)
12-19-06 06:22 PM
aust182
IS - 1st Gen (2001-2005)
06-28-01 07:32 PM
Quick Reply: Does the Front Nav. screen play DVD movies?
