Chipping paint on rims
I have a 04 GX. Noticed the paint is chipping off the rims on every wheel. What's my best option here? Yes buying new rims but is paint an option? Is it worth the hassle?
Unfortunately anything that you do will only be a short term solution. I sandblasted and refinished mine but it didn't take long for the finish to start failing again. It's a known issue with these trucks and had been discussed here many times.
Even after sandblasting and powdercoating the wheels will to continue corrode under the finish. In less than a year the powder coat will start to flake off like the original finish. Best option is paint or replace the wheels.
RZ500, yours look really good. I like the black color and would like black on mine as well. What paint did you use? What is your process? If it's not too intense I'd be willing to try. And you say every couple years you re-apply?
You could certainly give powder coat a try. It will fail though at some point and the only solution then is to sandblast and powder coat again. This process will get expensive fast as you will be paying to remove and reinstall tires each time. With paint though you can touch them up on the truck with a $10.00 can of spray paint.
The biggest challenge to the job is coordinating time with your mechanic and sandblaster. I did my wheels at the same time as my suspension mods and new tires. My truck was sitting on a hoist for a day and a half anyways so it was not difficult for me to get the wheels done. Otherwise you need a spare set of wheels or your truck will be sitting on blocks till the job is complete.
Thanks for the info. Is pressure washing an appropriate alternative for sandblasting? I have a pressure washer at home.
Did you also use a spray primer as well? What's the drying time for a project like this?
you can use super fine grit sandpaper and wet sand the wheels manually, and then use duplicolor self etching primer and duplicolor wheel paint, ive had good results with that method
i just took my stock wheels and had them sandblasted(mediablasted) and then used selfetching primer, then a primer filler, and then a primer sealer, then the color then clear coat over that. fallowing the instructions on the can and using the same brand of paint for all coats you should be golden, but just to note this will cost a good deal. i got a good deal with all 5 of my wheels being blasted for $100 and then i spent about $150-200 in paint supplys. so im at about $300 for my wheels, but its still cheaper than buying a new set of wheels. -fyi you will need to either leave the vehicle sit for a couple weeks on blocks or have a second set of tires and wheels like i did. but the results are worth it. take your time and dont rush it
