Towing Option
I notice on eBay a Toyota OEM 2 inch hitch receiver for a 4Runner or GX470. I did not get the receiver provided when I picked up my GX. Did anyone else have it provided as part of the option or do you have to buy it seperately? Not that I'll use it, but if it's suppose to be included, I'll be asking for one. The receiver cover wasn't on when we picked it up either, but they mailed me one.
I am not sure about the terminology regarding exactly what all the parts are called, but I did get a seperate cardboard box, which I think is the receiver that you mention. The box is labeled "Ball Mount Assy - 4Runner/GX470" and has a Toyota part number on it. The salesperson didn't make any comments about it, so I don't think he was doing me any favor by giving it to me (or I am sure I would have heard about "how he's helping me out" or something by giving it to me....)
Hope this helps!
Tony
Hope this helps!
Tony
Originally posted by Knicksfan
Same cardboard box, Toyota markings etc. It is now in my garage where I am sure it will sit until I need it and then won't be able to find it....
contains a ball mount hitch. It is the thing that you mount the ball into, insert into the receiver hitch which is bolted/welded to the frame either at the factory or after market, e.g., Reese, Drawtite, etc. This type of
setup would be good for a very small, lite utility or boat trailer. To tow a travel trailer or big boat trailer, you will need to get a "weight distribution" hitch. I have purchased an "Equalizer 4-point" hitch to tow my travel
trailer which I pick up next week.
I hope this helps.
Larry
Hope this helps!
Tony
Hope this helps!
Tony
Originally posted by etexmatt
... To tow a travel trailer or big boat trailer, you will need to get a "weight distribution" hitch. I have purchased an "Equalizer 4-point" hitch to tow my travel trailer which I pick up next week....
Originally posted by SacKen
I purchased my GX in Feb `04. The label on my hitch has the same rating, 6500 lbs, for both load-bearing and weight-distributing. So using a weight-distributor wouldn't buy me anything. Did they change the hitch that they deliver to require a weight distributed setup to reach 6500 lbs?
you can use the "Ball Mount" supplied with the car. This would be considered a "Weight Bearing" hitch.
In the GX's specs, you should find that the Max TONGUE weight rating for this type of towing is 730#.
Also, if you use a "Weight Distrubuting" hitch, then the Max Tounge weight = 1095#. Even though very
important, the real problem when towing a heavier trailer with a weight bearing hitch is that you will be placing too much weight on the rear axle, tires, etc., and the front will lift off the ground causing poor handing, premature tire faliure at the least. Lastly, I am not sure what you mean by your statement "setup to reach 6500#". The Max Gross Trailer Weight (if you want to stay within the limits of the GX) is 6500#.
BTW: A good weight distributing hitch rated at 5000 to 7000# runs around $300 to $600 new.
Hi SACKEN: Re the hitch as delivered on a GX 470. If you wish to tow a very small utility or boat trailer,
