Air pump noise?
Air pump noise?
Anyone heard the air pumping sound/noise when raising the rear height? I noticed the air pumping sound yesterday when my wife pushed the rear height mode to high while I was outside the car. Just wanted to check with you guys to see if it’s normal.
Thanks,
CJ
Thanks,
CJ
The pump cycling is normal. It should run a little when you first start the truck to bring it up to the proper height. I had a Lincoln with air shocks and it sounds the same, only that was all 4 corners so it ran longer, and you could here it from inside the car.
ap11
GX - 1st Gen (2003-2009)
15
11-17-17 01:32 PM
