Help Me Buy- Testing Function of 4 Wheel Drive
#31
Ya that's what someone else told me yesterday too...I only wanted the backup camera because I'm switching from a Volt to an SUV and parking in so cal is tight and am always worried about running someone over or hitting a car when reversing out of a spot (not to mention I don't want to back into a low pole or pony wall with my baby once I get her). That's a brillAnt idea for looking into after market backup camera and getting one without it. Any recommendations for that?
#32
If it's left-to-right, then the differential on that axle will be overworked.
Normally, I'd replace the spare with the best of the worn tires (driving on it a little ways to a repair shop is ok). But if the tire is 10+ years old I wouldn't even do that. I think you'll need 5 tires.
Costco has sales on Michelin every 2-3 months. It's usually enough to pay the sales tax.
Chip H.
#33
#35
Minor thread jack: Chiph9, can you explain to me how the torsen limited slip center differential can wear out from having different tire sizes? Also, aren't the open front and rear differentials being overworked every time you turn a corner? I fail to see how different tire size would/could cause a major malfunction. It appears to me that the open axle differentials are designed to take care of the difference in rotation between the right and left axle shaft, whether caused by turning a corner, or from differing tire sizes.
#36
It's the difference between taking a corner versus going in a straight line. You go around corners somewhat rarely when driving - the vast majority of miles you put on a vehicle have it going in a straight line (not even highway miles -- in the city too). The bearings and lubrication are designed with that usage in mind.
When you have different sized tires, it's like you're going around a corner all the time. The differential works much harder, which produces more heat. This wears the bearings down faster, and exhausts the lubrication sooner.
Chip H.
Chip H.
#37
Some cars are more prone to issues than others. It's fairly common practice on Subarus to shave a new tires to match the others in a situation where you need to replace only one tire (blowout, etc). Sucks paying extra to pre-wear your new tire, lol.
#38
the high low light on the dash is for the suspension, not the transfer case if you were looking at that one.
I havent come across a gx or 4runner where the case didn't center lock or shift from high to low, normally if high low is broken the transfercase will be messed up and you will know when driving. Its possible for the center lock to be not working especially if someone repaired the common leak themselves incorrectly. as for the leak just look at the bottom of the case if its dry its good, if its wet its got the leak.
you dont want different size tires from left to right very long, not only is it overworked like they said, but when you have an imbalance and then turn, the diff is compensating in a larger range then its used to and can overwork that way as well. if you have to run a spare smaller tire always put it on the rear axle and get it changes as soon as possible with a regular size, its actually in the manual. Never put the smaller tire on the front axles, it messes with the steering and stopping pretty badly and is dangerous, if you have a flat in front, you shift the rear tire to the front and put the spare on the rear, well at least by the book if you have a smaller spare, same size spare you can put anywhere on the car.
#39
I'm sure they're out there, but I haven't see a tire store yet that will shave a tire. ![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
My sister had a Cadillac SRX at one time. Not only were the tires different sizes front & rear, but they used directional tread as well. Which meant she couldn't rotate them. When she had an alignment issue, the AWD system meant she had to buy four new tires at $250 each. Ouch.
Chip H.
Chip H.
#40
Chip H.
Chip H.
#41
You mentioned one used car dealer that you felt had a low-pressure sales approach. Ask them if the would represent you at an auction. Or just ask around ... I have no doubt there are plenty of small dealers in the San Diego area that go to auction for a flat fee. I see dealers from there out at the Nevada auctions all the time.
ajortiz
GX - 1st Gen (2003-2009)
08-01-13 05:40 PM
