07 GX 470 Drive Cycle
Old 01-07-16, 07:38 AM
memokc
memokc's Avatar
Default 07 GX 470 Drive Cycle
Don't mean to sound ignorant but what does Lexus consider a drive cycle? Is it set by miles, how many times the vehicle has been started or what? Just curious because have always wondered.
Old 01-08-16, 08:00 PM
mswtoyota
mswtoyota's Avatar
I would assume that a drive cycle is starting and driving the vehicle, then turning it off. Similar to a key cycle?
Old 01-09-16, 09:53 PM
Jaysmith2k
Jaysmith2k's Avatar
Here's the drive cycle:
Toyota/Lexus OBD-II Drive Cycles
Posted by Alex (Im) E. on 31 January 2013 11:55 PM
Toyota/Lexus use a series of diferent drive traces for each system monitor.
It's possible that more tan one monitor may run while doing a particular drive trace, but here's the official procedure from Toyota/Lexus:
EGR MONITOR DRIVE CYCLE
All models 1996-2002
Pre-Conditioning Requirements:
MIL must be off.
Altitude is below 7801 feet (2400 m).
IAT (Intake Air Temperature) must be above 13E F (-10E C).
1996-2000 Land Cruiser / LX 450 ECT must be below 104E F (40E C).
Driving Procedure
Connect Scan tool in order to observe data stream and monitor status.
If IAT is less than 50E F (10EC) at engine start-up, idle engine for 10 minutes.
Notes: Do not exceed 30% TPS. Maintain smooth throttle inputs, avoiding sudden accelerations.
Exception: 1996-2000 Land Cruiser & LX 450- Begin driving immediately.
Drive the vehicle at a steady speed between 43 & 56 mph (70-90 km/h) for three to five minutes.
Stop the vehicle and idle the engine for 3-5 minutes.
Repeat steps 1-3 once.
Notes: Readiness may not switch to complete if a pending code was set during the drive trace. Toyotas do report pending codes (using an enhanced scan tool). Pending codes are not considered a failure, and typically must be duplicated in order to set a DTC & MIL.
AIR/FUEL SENSOR HEATER MONITOR DRIVE CYCLE
MIL must be off.
Driving Procedure:
Start engine and allow it to idle for 9 minutes.
Drive the vehicle at 25 mph (40 km/h) or more for at least 2 minutes.
CATALYST (NON-A/F SENSOR) MONITOR DRIVE CYCLE
Certain Models 1996-2002
MIL must be off.
ECT (Engine Coolant Temperature) must be 176E F (80E C) or more.
IAT (Intake Air Temperature) must be 14E F (-10E C) or more.
(2002 MY vehicles will run monitor at temperatures below 14E F by cycling key to OFF and repeating drive trace).
Driving Procedure:
Note the IAT data for use in step 3.
Drive the vehicle at a steady speed between 40-55 mph (64-88 km/h) or more for 7 minutes if IAT was below 50E F (10E C) at start-up, or 3 minutes if IAT was above 50E F (10E F) at start-up.
Drive the vehicle at 35-45 mph (56-72 km/h) for 7 minutes.
NOTES: Maintain smooth throttle inputs, avoiding sudden accelerations. Avoid sudden deceleration with closed throttle as much as possible.
CATALYST (A/F SENSOR) MONITOR DRIVE CYCLE
Certain Models 1998-2002
MIL must be off.
Driving Procedure:
Drive the vehicle allowing speed to fluctuate between 35-45 mph (56-72 km/h) for 16 minutes.
Notes: Maintain smooth throttle inputs, avoiding sudden accelerations. Avoid sudden deceleration with closed throttle as much as possible.
EVAPORATIVE (VACUUM PRESSURE TYPE) MONITOR DRIVE CYCLE
Certain Models 2000-2002
MIL must be off.
Fuel level is between 2 and 3/4 full.
(Preferred values- monitor may still run with tank fill between 15% and 85%).
ECT & IAT is between 40 & 95E F (4.5-35E C).
Cold Soak Procedure is complete (see below).
IMPORTANT:
A cold soak must be performed prior to conducting the drive pattern in order to complete the Internal Pressure Readiness Monitor (see below).
Cold Soak Procedure:
Let the vehicle sit 8 hours, or until the difference between IATand ECT is less than 13E F (7E C).
Driving Procedure:
Release pressure in the fuel tank by removing and re-installing fuel cap.
Start the engine and allow it to idle until ECT is 167E F (75E C) or more.
Raise the engine speed to 3,000 RPM for ten (10) seconds.
Idle engine with the A/C on (for additional load) for 15-50 minutes.
(If no A/C, set parking brake and chock wheels. Once immobilized, idle vehicle in drive).
EVAPORATIVE (WITH NO LEAK DETECTION) MONITOR DRIVE CYCLE
Certain Models 1996-2000
MIL must be off.
Altitude is below 7801 feet (2400 m). ECT is 181E F (83E C) or more.
IAT is 41E F (5E C) or more.
Driving Procedure: (this is the same driving trace used by the EGR monitor).
OXYGEN SENSOR MONITOR DRIVE CYCLE
Certain models 1996-2002
MIL must be off.
Driving Procedure:
Drive the vehicle at a steady speed at or above 25 mph (40 km/h) for at least 50 seconds. Maintain engine speed above 900 rpm.
Stop the vehicle and allow the engine to idle for 40 seconds or more.
Repeat steps 2 & 3 nine (9) more times.
AIR-FUEL RATIO (OXYGEN) SENSOR MONITOR DRIVE CYCLE
Certain models 1998-2002
MIL must be off.
Driving Procedure:
Start the engine and allow it to idle 2 minutes.
Drive the vehicle at a steady speed between 40-70 mph (64-112 km/h) or more for 3 minutes. Maintain engine speed between 900 & 3,200 rpm.
Stop the vehicle and allow it to idle for ten (10) seconds or more.
Drive the vehicle at a steady speed above 25 mph (40 km/h) or more for at least 40 seconds. Maintain engine speed above 900 rpm.
Repeat steps 5 & 6 nine (9) more times.
Source: Toyota
TIP: Tune Your Car with Powerful Diagnostics Software
car obd software
It's simple as hooking up the interface and loading up TOAD PC/laptop software.
Whether you're a home car owner or an auto mechanic — you can save thousands of dollars on car maintenance, save time and effort on repairs, and dramatically improve your cars lifespan/performance — by getting yourself a professional car diagnostics scanner.
They're called OBD scan tools. And will give you an instant overview of your vehicles condition by tapping into it's computer chip.
But more importantly, you can also obtain software that will allow you to edit the cars performance data. Like adjusting RPM, fuel injection, etc. This is what car performance shops charge thousands of dollar for — to allow the car to operate more fuel efficiently, faster or with stronger torque/BHP.
The good news is, you can do the same at fraction of a cost, with a USB connection interface to your laptop, and car tuning software. We suggest you Google on this to discover more. Or you can get this car diagnostics/tuning package here.
stlgrym3
GX - 2nd Gen (2010-2023)
13
09-07-18 12:42 PM
MPLexus301
12-05-13 11:21 PM
ShaggyRogers
GX - 1st Gen (2003-2009)
01-15-05 09:12 AM
DrewGS4
03-02-03 10:17 AM
Quick Reply: 07 GX 470 Drive Cycle
