Help - cannot open passenger door after changing actuator motor
Hello,
I changed the actuator motor on the DS passenger door. Now the door does not open. The electronic lock moves, locks and unlocks but the door does not open from inside or outside. After a few tries the lock tab chatters but the door still does not open. Can someone please help with what could be wrong? As far as i know i put it back together, like i took it out.
If someone can just help on how to take the panel off from inside then i can atleast get to the two wires that go to the lock and see if i can open the door to take the actuator out once again.
Thank you. I really sppreciate someone chiming in.
Here is the method for removal and refit. And also the wiring diagram for the Door lock system 1 & 2. Do let us know the outcome.
ericwat
04-25-17 01:38 AM
