Coolant leak, not radiator, water bypass joint? Help please
Help! Apparently my celebration was premature. There is no longer any leakage at that slip joint, it's all dry and clear, but coolant continues to slowly drip down the engine block and drip off the lower frame cross member and front of the transmission.
Has anyone had a leak elsewhere? Somewhere underneath the intake manifold? I can't see a leak, but there is moisture on top of the block, just behind that bypass joint tube...
