Air Suspension disables in Freezing Temps
There has been below freezing temperatures here in NYC and I noticed that the air suspension is disabled when left out in the cold.
The fist time I noticed this was when the temperature was 15 degrees and while driving the ride was very bouncy. I noticed I didn't hear the air compressor coming on. I tried raising the suspension from "N" to Hi or Lo but nothing happened when I pressed the button, not even the light, it just remained on "N".
I parked inside the garage and after about 20 minutes I heard the air compressor running and felt the car leveling itself. I was also able to adjust the by using the height control switch.
I have come to the conclusion that the cold weather is causing the air suspension to be disabled.
Has anyone experienced ?
I'm thinking the suspension should work at these temperatures. Am I missing something?
Is there any DIY for removing moisture from air suspension?
Probably water getting inside the height sensor and freezing.
Chip H.
Chip H.
FatherTo1
07-22-17 08:37 AM
