2004 Front & Rear Shocks
Old 02-21-16, 01:43 PM
angelslex
angelslex's Avatar
Default 2004 Front & Rear Shocks
Finally got some nice weather to do the suspension on the GX.
Rear Shocks were cake to do but the front shocks you are going to put some elbow grease in there.
For the next one we already know to just take off Stabilizer bar and loosing up the bolt joint adapter 2 19mm bolts I think. Remove the top 3 screws and pull out. If it doesn't come down just grab a screw driver to separate it from the top plate."is stuck" like glue.
Good luck
Old 02-21-16, 03:14 PM
Morphyne
Morphyne's Avatar
Very nice. How is the ride? One thing to add is that there is a method where you do not have to use spring compressors.
Old 02-21-16, 03:36 PM
angelslex
angelslex's Avatar
These are the front shocks i used
Bilstein 24-239370 5100 SERIES RIDE HGHT ADJ.
Rear Shocks are these
Bilstein 33-187174
Old 02-21-16, 03:42 PM
angelslex
angelslex's Avatar
The ride is way better than what I had in the last couple of years. The truck is use as 3rd vehicle now. Mustly local errands so the ride is worth the money I spent all 4 shocks and labor to my buddy to help me out. $550
Bilstein Shocks are nice.
Old 02-22-16, 02:24 PM
NTH
NTH's Avatar
Wow nice job. Thanks for the pics.
Old 02-22-16, 03:04 PM
co4wheel
co4wheel's Avatar
Very nice. It's interesting to hear your ride is way better while some people say the same shocks are rough. I don't get it as I never felt the Bilstein are harsh. Any comment?
Old 04-12-16, 06:49 AM
roemer7
roemer7's Avatar
Thanks for the write up. I just ordered a complete set of 5100s. I'll let you guys know how the install goes.
Old 04-12-16, 09:47 AM
t4mudn
t4mudn's Avatar
Any lift on your gx or is it still at stock ride height?
I need to replace my wife's shocks and just debating on options. She does not want any kind of lift, but I would like to go to coils instead of the air bags.
Thanks
Old 04-14-16, 03:57 AM
angelslex
angelslex's Avatar
IMHO It looks like the same hight as the OEM. To make your job easier take the crossbar out. At first I was been lazy but on the second one I decided to just do it and it was so much easier. Good luck
Old 04-14-16, 05:36 AM
roemer7
roemer7's Avatar
Did you set the spring perch at the lowest setting for the front?
Old 04-14-16, 03:28 PM
angelslex
angelslex's Avatar
Yes. It comes to the lowest setting by default.
Old 04-14-16, 07:05 PM
roemer7
roemer7's Avatar
Thanks. Mine arrive via UPS tomorrow.
Old 04-14-16, 07:49 PM
co4wheel
co4wheel's Avatar
If it's on the lowest setting with the same stock springs it should be the same ride height
Old 04-24-16, 02:25 PM
bluedurama
bluedurama's Avatar
Just did my shocks and struts with the Bilstein 5100's. Had a heck of a time compressing the front shock enough to get it in place. Finally taking the two bolts that hold the ball joint on gave me enough room (with a generous pry bar-down) to get them in place. I don't know what I would have done if I chose to use one of the other adjustments (up). The ride is exactly what I wanted.
Old 04-24-16, 05:24 PM
co4wheel
co4wheel's Avatar
My experience as well. I just removed the lower control arm.
angelslex
GX - 1st Gen (2003-2009)
01-18-16 08:47 AM
GRAYM
16
09-01-13 09:43 AM
kevwats01
04-23-12 12:39 PM
boris
01-06-11 02:23 PM
Quick Reply: 2004 Front & Rear Shocks
