Preventing Frozen/Rusted Calipers
Mine are great NOW. I don't mind doing a little preventive maintenance to keep them from freezing up in the future. Never ever had a piston freeze/rust up inside a caliper. Never seen it. Don't know what to do to prevent it. Is a seal failing allowing water in to rust? Whats the deal?
^ Not sure if that is going to work for the front calipers. They use slide pins that are not enclosed so greasing them is not going to really do to much for the piston freezing.
The only thing I could maybe see being a preventative measure would be to takt the caliper off the rotor. Remove the brakes and grease the boot where the pistons come out. Other than that, once moisture gets in there, its only a matter of time before it wears on the slip-o-ring.
I bought the caliper repair kit and I rebuilt both front calipers. The pistons weren't sticking bad and after cleaning them and greasing them with the supplied lube, they moved freely. I think the key is to keep the pistons greased and the boots sealed tight. The kit comes with the rings that keep the boots sealed.
This the kit, not too bad of a job but definitely time consuming:
Amazon.com: Lexus 04479-60081, Disc Brake Caliper Repair Kit: Automotive
i found an interesting article regarding the use of Castrol red rubber grease for brake pistons. It is rubber compatible for the seals and not petroleum based so it will not contaminate brake fluid. It also contains a rust inhibitor and used in applications like motorcycle shocks.
I lost the original article i was reading but here is one that outline its uses http://www.redrubbergrease.com/
Thanks.
So you'll replace rotors instead of machining them but you'll rebuild a caliper instead of replacing it?
And I buy quality rotors. Not the cheapest. But I would use cheaper rotors before I machined the ones on my truck which are already likely cheap Chinese as I bought it used
