Potential Stereo Upgrade ?'s (non-nav)
I did a search and this looks like the best & most current thread on this topic for us non-nav owners. Let's keep it going
I'm Curious has anyone tried the focal speakers mentioned in the first post? They look nice.
Can anyone answer the midrange speaker question? " Do I need to replace the factory mids, or can I eliminate these? "
OP, how'd it go with those harnesses?
I don't think the focal integration speakers are any match for the Infinity Kappa 60.11CS, and right now they're both around the same price, the infinity's used to cost a lot more. Sure you have to buy or make an adapter but it would be worth the effort. My Dodge truck uses the 6x9's in the doors as well, and I chose the Kappa 60.11CS over the Focals and made an adapter out of Luan. Driven with an Alpine amp at 2 ohms the sound is phenomenal.
I'm not completely sure the Kappas will clear the window track and such, so you'd want to check that before deciding. On my Dodge there was plenty of clearance.
You can just disconnect the midrange speakers, no need for them.
Has anyone upgraded the stock 6.5" sub in the back panel? I was planning on getting a JL microsub or maybe a 10" box under the passenger seat, but I'm curious about trying an upgraded 6.5 in the stock location.
I ordered the Pioneer AVH-2330NEX from Crutchfield with the accompanying harness to keep the stock speakers, amp, sub, etc. and a back-up camera (wired). I ordered the trim kit from eBay. It should all be sitting at my door when I get home from work, so this afternoon should be fun.
OP did you have any issues with the install I need to prep for?
If the Kappas will fit and you don't mind the little bit of custom work making or buying an adapter, they are going to sound better.
I am planning to upgrade the stereo at some point and have a few questions about potential options. The list below is what I am kind of thinking I'll do, along with some options that I hope you guys can help me sort out or provide other suggestions.
Stereo
Something with Apple Carplay
Dash Kit Options
Beat Sonic
Ebay BS Knockoff
Wiring Harness Options
Beat Sonic SLA-Kit
Metra
PAC
Access
Front Door
Focal ISS 690 (5-80w)
6x9 Component
Mid Range
Rear Door
Focal ISC 165 (5-70w)
6 3/4 2-Way
Subwoofer
I guess I will have to trim the factory box to accept a 6 1/2" sub. It looks like most of the options list 150W RMS.
I really wish we had the 8" 4runner option! I have searched until the end of the internet for a simple swap to make 8" happen in the factory location, but have not had any luck.
Amplifier (4ohm) Options
I feel like my options are really limited here as well by utilizing the small factory subwoofer location.
RE Audio (63wx4)(180x1)
RF Punch (75x4)(200x1)
Amp Wiring
Is the factory wiring acceptable or should I go ahead and at least run a new, larger 12V?
Anyway, what are your thoughts? Any pointers you can provide would be greatly appreciated.
Thanks,
Cole
Stereo
Dash Kit Options
Beat Sonic
Ebay BS Knockoff
Beat Sonic SLA-Kit
Metra
PAC
Access
Front Door
6x9 Component
Mid Range
Rear Door
6 3/4 2-Way
Subwoofer
Amp Wiring
Thanks,
Cole
Agree. Speaker choice makes the most significant portion of how a system sounds. Spend the largest percentage of your budget on them, and spend a lot of time making sure their "sound" matches each other, and what kind of music you listen to.
Chip H.
Chip H.
Ok so stupid question guys... If I have a non nav / Non mark lev GX.. do I still have a OEM amp?
I'm trying to figure out exactly what I need to install.
I've got the trim piece and headunit. Do I need just a harness? Or if I do have a OEM amp, how do I connect it to the new head unit?
Sorry guys, I can turn a wrench, but I'm stereo dumb!
Beat Sonic SLA-81AD
I'm not an expert on the non-Nav wiring, so there may be a cheaper adapter available or you may be able to cobble your own adapter together.
For those of us WITH factory navigation, I stumbled on a new product that might just be the solution many of us have been waiting for:
Beat Sonic MVA-81
jpmotdyn
07-11-02 08:07 PM
ndisgii
06-26-02 03:34 PM
