Driver side moulding clips help
Old 09-08-16, 06:09 PM
zaccor
zaccor's Avatar
Default Driver side moulding clips help
First, I have to say this forum is absolutely the best.
Second, my driver side door panel is loose at the bottom. Enough that I can pull apart the panel and see these little blue clips that are supposed to keep the door and the panel together. I can see some of them are broken. After some research I've concluded I need to replace the clips. I've found some on Amazon but wanted to verify they are correct. I assume I use some needle nose pliers, pull out the old ones, put in the new clips, and press the door and panel together to engage the clips?
Posted two pics. First is what it looks inside the panel/door with the clip. Second is the replacement product at Amazon.
Attached Thumbnails Driver side moulding clips help-image.jpeg   Driver side moulding clips help-image.png
Old 09-09-16, 08:57 AM
tomtbone
tomtbone's Avatar
Is the this the exterior lower moulding piece? I have the same problem if so.
Old 09-09-16, 07:49 PM
zaccor
zaccor's Avatar
Yes it is. I get the clips tomorrow and I'll report back.
Old 09-19-16, 09:20 AM
tomtbone
tomtbone's Avatar
any progress on this? are these the right clips?
ehoodiii
04-25-06 10:52 AM
1sxyrxy
SC- 1st Gen (1992-2000)
02-09-06 05:34 PM
tmyslivy
Maintenance
11-30-04 07:44 PM
Quick Reply: Driver side moulding clips help
