Rear gate door light issue
Old 01-16-17 | 10:59 AM
khan300c's Avatar
khan300c
Default Rear gate door light issue
Hi,
I have a 2005 GX 470. Whenever I start driving or give it some extra gas, the rear tailgate dome light turns up indicating the door is open and once I slow down it will go away. it also indicate in the dash that some door is open. I tried pushing in the little sensor needle on the door in and out many times but that did not help. Is or did anyone ever experience it? are there any fix to it?
Please help me out.
Old 01-16-17 | 11:04 AM
IanB2's Avatar
IanB2
Mine used to do that when it was cold, tried a few things, but the only thing that worked was replacing the rear hatch switch. Hasn't been an issue since.
khan300c (01-16-17)
Old 01-16-17 | 11:10 AM
180ls1's Avatar
180ls1
Had the same issue. Make sure everything is tight first of all. I hit that circle hook with a sledge hammer to push it in just slightly and it went off. Have not had an issue since. A Lexus tech told me that trick FYI.
khan300c (01-16-17)
Old 01-16-17 | 11:11 AM
khan300c's Avatar
khan300c
Much appreciated Ian, btw do you happen to know the specifics of the switch? is there anyway I can search it?
Thanks,
Old 01-16-17 | 11:18 AM
khan300c's Avatar
khan300c
Thank you for your reply. can you please specify what kind of circle hook are you talking about? I am sorry but I do not know which one is that.
Thanks,
Old 01-16-17 | 11:37 AM
180ls1's Avatar
180ls1
Thanks,
That one that is bolted to the body by the drivers side tail light. Not the rear swing gate. Its the thing that the swing gate locks on to.
Old 01-16-17 | 12:01 PM
IanB2's Avatar
IanB2
Thanks,
Just go to the dealer and ask for the rear hatch switch, it wasn't a real expensive part, after shipping you'd be no further ahead sourcing online I would think.
Old 01-16-17 | 04:30 PM
mrblister's Avatar
mrblister
You could just glue a rubber disk to where the switch push rod contacts the door that would tale up any slack and that might be the fix
Old 01-16-17 | 05:03 PM
Listers's Avatar
Listers
This is what I would try. Buy something like this and put it on the door where it mates with the switch. https://www.amazon.com/uxcell-Cylinder-Adhesive-Rubber-18mmx12mm/dp/B00H8UUEX8/ref=sr_1_5?ie=UTF8&qid=1484611323&sr=8-5&keywords=rubber+foot+pads Could even find something like this at home depot
Old 01-17-17 | 07:02 AM
chiph9's Avatar
chiph9
You want p/n 84235:
http://www.lexussouthatlantaparts.co...rimLevel=19100
Chip H.
Old 01-17-17 | 05:54 PM
LoneHiker's Avatar
LoneHiker
Mine did this when I first bought it. There's no need to spend a bunch of money...
The actual door pin switch is on the driver's side by the taillight. It has a black round rubber cover over it. Now look on the door and you will see the round spot where the switch contacts the door. Stick several layers of a thick tape there, such as electrical tape or duct tape. Problem solved.
garyr
12-02-16 07:58 PM
Autoplak
10-26-16 08:30 AM
jbdvm1988
GX - 1st Gen (2003-2009)
02-13-12 09:05 PM
Bunkey
03-12-09 06:51 PM
DASHOCKER
03-23-06 12:06 AM
