Drivers side AC not working
Old 02-12-17, 09:09 AM
Hermyherm
Hermyherm's Avatar
Default Drivers side AC not working
My drivers side AC is not working but the passenger side AC is blowing out cold air. Any thoughts?
Old 02-13-17, 07:29 AM
chiph9
chiph9's Avatar
Check the simple/cheap thing first - that your dash vents on that side are set to allow air to flow and are directing it towards you.
Then run the A/C system diagnostics:
https://www.clublexus.com/forums/per...eed-codes.html
Chip H.
ASE (07-27-23)
Old 02-13-17, 08:42 AM
BradTank
BradTank's Avatar
Common issue, the AC system is likely low on refrigerant, mine did something similar where one side starts blowing luke warm while the other blows cold. The rear AC will also not be cold.
I took it to a dealer years ago, told me they think it's a leak in the rear evaporator but weren't sure (couldn't find traces of dye) and that it wasn't cost effective to fix, so I just top it off once every year or two with a can of R-134 and my AC is ice cold. Seems to be a pretty common problem around here.
It didn't make sense to me that low refrigerant would have different cooling for different sides, but I guess it's how the vents are routed. My first guess was a blend door.
Jdconrad06 (05-27-20)
Old 02-14-17, 04:47 AM
kwkshift
kwkshift's Avatar
Probably low refrigerant. This happened to me last year and thats what the problem was. Well, that and a leaking evaporator.
Old 06-14-23, 04:16 PM
eleight
2nd gear
eleight's Avatar
Default Same thing on my GX460
my 2010 GX460 does the same thing. Not the freon for sure( it was on a green when I checked). Passenger side is ice cold. And the driver side is blowing air, but not ac cold. It happens when I keep the thermostats on low. On 65 it gets better. After running the car for 15-20 minutes both sides start blowing cold again
Old 07-26-23, 09:24 AM
dan25man
dan25man's Avatar
I am having the same issue as the OP. My passenger vents are warm while the drivers side is cold. The freon level was low. I have dye in it now. So far no leaks presenting themselves yet. I found a thread here about the same issue. I guess the dealer traced it to a bad compressor clutch? Idk. If I refill the system with freon the passenger side is cold again. So I don't think it's the clutch. I think it's just how air is passing over the condenser where the drivers side air get cold and warms up the condenser but then the passenger has no cold left.
I was hoping there would be a leak on the condenser, but so far haven't seen any evidence of leaks there. Hoping it's not the condenser in the dash.
Old 07-26-23, 09:35 AM
ASE
ASE's Avatar
Received 1,027 Likes on 685 Posts
If one side is cold and the other is warm at the same temperature settings ... then this points to a zone control issue ... meaning not a compressor or freon fill issue.
Old 07-26-23, 07:10 PM
Johnny Rad
Johnny Rad's Avatar
Pray it's not compressor evaporator, which is nestled deep in the dash...
Old 07-26-23, 07:47 PM
ASE
ASE's Avatar
Originally Posted by Johnny Rad
Pray it's not compressor (?), which is nestled deep in the dash...
Sorry ... but the Compressor is in the engine compartment driven by the engine via belt ... the Evaporator is under the dash ...
Last edited by DaveGS4; 07-27-23 at 09:33 AM. Reason: Need to stop the negative comments towards others if you disagree
Johnny Rad (07-27-23)
Old 07-27-23, 04:27 AM
chiph9
chiph9's Avatar
There usually isn't a leak, per-se. It's commonly the system slowly losing refrigerant over 15+ years (which isn't surprising)
Go ahead and add dye when you refill the system, but chances are it won't show up for the UV light.
Chip H.
Old 07-27-23, 09:20 AM
ASE
ASE's Avatar
This post has gone into the weeds. There is ONE evaporator under the dash that feeds both the driver and passenger side. If the passenger side has adequate cooling as the OP stated ... this indicates that the A/C system is fully charged and functional. This then points to a zone control issue ... and NOT freon fill or otherwise.
Old 07-27-23, 01:55 PM
chiph9
chiph9's Avatar
It's a common sign that the charge is low. I had it myself. Search the forum history.
Chip H.
2wPushkins (08-28-23)
Old 08-21-23, 03:19 PM
2wPushkins
2wPushkins's Avatar
I first noticed No AC in my 2006 es330 the first time I put it on this summer. Since we are in the 90s now, it's more of a problem. Can anyone tell me where the port is to put in freon? I've looked around under the hood and googled but can't find info for a 2006. Thanks
Old 08-22-23, 02:18 PM
matthewlp
4th Gear
matthewlp's Avatar
How would one go about checking if this is the problem and/or fixing it?
Thank you
Old 08-22-23, 06:31 PM
chiph9
chiph9's Avatar
@2wPushkins - Sorry this is the GX470 forum. No idea on location for an ES.
@matthewlp - Here's how to enter diagnostics and how to step through the options:
https://f01.justanswer.com/dcraig100...dc2a5_eee2.pdf
Chip H.
Quick Reply: Drivers side AC not working
