Stuck ingition cylinder
Read several threads regarding this subject. First I'm going to try and spray to Triflow or Houdini lubricant in the cylinder to try to alleviate this issue. Local locksmith suggested those lubricants and said not to spray graphite or WD40. It this doesn't work then he suggested that I but a new ignition cylinder and he would swap it out and rekey it. He said what happens is that the tumblers have gotten weak over time, or there is gunk inside preventing the tumblers from moving freely.
If I have to buy a new cylinder, I would assume I need to buy it from a Lexus dealer, or would I be able to buy a new cylinder without having to pay dealer gold price for this part. If I need to buy from a dealer, who is the preferred dealer on this site now?
What is happening? Key stuck in it? Wont turn the truck on? Just a quick comment, did you make sure there is not any tension on the steering wheel? I have used Lexuspartsnow also southatlantalexus. Just kind of shop around. When I had to buy the whole shifter assembly due to "detent" I shopped around and found it a lot cheaper at 1 Lexus site than others. Sounds like you are, but stick with a Lexus part. Just start to google away! OH! A tip I learned a long time ago, take a pencil eraser and use that to clean the actual key, it actually works good, especially the ways our keys are cut. I know your key isnt the issue, but im sure it can get the cylinder inside dirty over time.
So the key goes in and out, wont turn the truck over? IDK what kinds of lubes you mentioned are, but I would 1st get a can of CRC electrical cleaner and spray several shots inside. I know its not a electrical issue, but the springs collect dirt and dust etc. In between inserting and removing your key. I would do that a dozen times or so to clean and clear any junk. Then get a lube, which may be 1 you mentioned, that sprays liquid, then kind of thickens up a bit, using a very littleon the key and in the tumbler.
To minimize wear on the mechanical parts of the ignition cylinder, make sure your keychain doesn't have much on it. Extra weight (flashlights, bottle openers, Tiny Troll dolls, etc.) drag down on it and cause wear.
Chip H.
Chip H.
The pins inside get bent. This happened on my GX because my wife normally drives a stickshift, so when she drove the GX she forgot to put it in Park before turning the engine off, and the key wouldn't release. She decided to go tribal on the key to get it to release, and now a pin is bent and the key jams up sometimes.
Lubricant helps a lot with this problem. And if you have a spare key, try using the spare. It will have less wear on it and should press the pins in better.
The cheapest permanent solution is to just remove the bent pin and put the lock cylinder back into service without it. It's up to you to decide if that's a security risk or not, since GX's have electronic starter disable anyway.
