Low Windshiled Washer Nozzle Pressure
This is obviously not a problem that would be specific to a GX, but figured might as well start here.
When I bought my GX, the passenger side washer nozzle wasn't working.
It looked to me like the hose was too short and pinched, but the service guy said instead that the actual nozzle itself needed to be replaced. Upon it being replaced, both nozzles worked fine for a short time and then suddenly, oddly the pressure from the nozzles dropped.
The washer fluid light never went off, and I made sure the reservoir was full. But pressure is still low.
what the heck is going on?
Might have dirt in the pick up from the water tank. Try to gain access to the hose in an area you can reach and blow pressure into the tank that might clear your issue there also [ I don't know for sure ] might be a filter on the end of the tank hose that plugs in to the bottom of the pick up not sure . But id you can trace the hose back to the tank you mighty be able to clear it with air \pressure
Interestingly, the rear windshield washer nozzle seems to be operating with the proper pressure.
thanks!
now what? Can I fix this myself with little drama? Or is this a shop thing?
sorry, it took me a while to actually remember to check this out... yes, there seems to be a leak as there is a large puddle and washer fluid visibly dripping from the skid plate while there is very little actually spraying on the windshield.
You may need to investigate a little further, perhaps pull the skid plate and have a look when someone is using the washer......................report back
SC400slide
Performance & Maintenance
07-01-13 08:00 PM
