2008 GX470 one rear window will not go up.
Old 09-01-17, 02:26 PM
Retrovike
Retrovike's Avatar
Default 2008 GX470 one rear window will not go up.
2008 GX470 one rear window will not go up using the drivers buttons. It will go up using the rear window switch. Dealer says I need Body Control Module and gives part number 82730-60092. Location - per Lexus estimate is left side junction box , left side under dash fuse box.
Got the car back recently from them repairing and repairing left two doors. I wonder if they maybe did not reconnect the cable to the passenger door window switches correctly or bent a pin on the connector putting it back together.
I started checking on the part number and someone said this was not the BCM but rather a block assembly on the instrument panel junction.
Thanks for your help.
Old 09-01-17, 06:16 PM
tz693
tz693's Avatar
You may just simply need a reset. Search the forum for window RESET.
Old 09-02-17, 03:18 PM
Booyah
Booyah's Avatar
Yep do a reinitialize to all the windows! Here you go and let us know if this does the trick!!
​​​​​​https://www.clublexus.com/forums/gx-...-or-reset.html
ATXChris (09-11-17)
Old 09-02-17, 03:30 PM
Lexusdk
Lexusdk's Avatar
So are both rear windows inoperative with the master switch? How about the passenger window?
Roll the rear window down all the way with the rear switch. Then roll it back up all the way until it closes, but after the window closes continue holding the switch up for at least 2-5 seconds. Then retry using the master switch to see if you can control the rear window.
Old 09-10-17, 05:23 PM
kbc
kbc's Avatar
i have the same problem on my '05. it's not the reset routine. i replaced the master control switch itself and that didnt help. let me now what you find.
Old 09-11-17, 04:36 AM
ATXChris
ATXChris's Avatar
Great tip - I started having this problem with the passenger front window a few days ago. Simply held it down, held it up, counted to five and was good to go. Thanks!
Old 09-11-17, 08:31 AM
Booyah
Booyah's Avatar
I love how these guys ask a question and you never hear back from them what the fix was--Jeez
jcoleman3
ES - 6th Gen (2013-2018)
08-09-17 10:49 AM
honey917
07-02-15 12:43 AM
dd0615
04-04-13 06:29 PM
andybisnut
08-28-12 11:29 AM
SamT170
12-15-08 04:10 PM
Quick Reply: 2008 GX470 one rear window will not go up.
