150k miles service items?
2006 GX470- Im approaching 150k and would like to know what do I need to address at this milestone? I called local dealerships, Lexus and Toyota, independent Lexus service...they all give me different answers.
Another user said I should do the 50k service.
Is there a known rule as to what gets repeated? Like do the 50k for 150k, 60k for 180k or something like that?
What was changed at 100k miles? Any catch-up work to be done?
Otherwise my personal recommendations are:
Oil + filter every 5k
Tire rotation every 10k
Coolant every 3 years
Brake fluid every 3 years (2 years if you live near an ocean or Great Lake)
Power steering fluid every 5 years (or so)
Spark Plugs every 100k
Timing belt service every 100k
Transmission drain + fill every 30k (this changes about 1/3 of it)
4WD service every 30k (3 differentials & lube the zerks)
At any of the above: Inspect the shocks, airbags, CV joint boots, etc. for leaks, damage, or wear.
Chip H.
Chip H.
A major service is done every 30k miles so you are due for one at 150k. I just did these today:
Oil/Filter 6.5 qt
Air filter
Cabin filter
Brake Flush
Coolant -i skipped this since it was replaced with timing belt at 90k with Super Long Life coolant
Front diff fluid 1.5 qt
Transfer case fluid 1.5 qt
Rear diff fluid 3.3 qt
Tire rotation
Grease all zerks fittings
Top off fluids
Hope this helps.
Oil/Filter 6.5 qt
Air filter
Cabin filter
Brake Flush
Tire rotation
Top off fluids
Hope this helps.
rclab1
01-18-07 02:48 PM
