Will GX460 brake calipers fit on the GX470?
Old 04-28-20, 02:14 AM
JohnPittma
JohnPittma's Avatar
Thanks for the tips!
Old 06-12-21, 09:02 AM
MobiusR
MobiusR's Avatar
Originally Posted by captainva
For the calipers only replace the fronts with the GX460 calipers. I'm pretty certain that the rears are the same for both. Stainless lines definitely help reduce the spongy feel because when you brake, the lines can't bulge out like the rubber ones so all of the fluid goes directly into the caliper. Changing out your brake fluid will help too but stainless lines make a bigger difference. At the end of the day its still a truck so the spongy feel is probably 50-60% gone and now light pedal pressure like the weight of your foot slows the truck where as before it did nothing for me. For the SS lines I used the following:
Front: StopTech 950.44007
Rear Calipers: StopTech 950.44507
Rear Center at Axle: Metaltech CRWN-FJC-REAR
This thread has all the info you ever wanted to know about brake lines:
https://www.toyota-4runner.org/4th-g...line-info.html
Likewise this tread has all the info you need about the brake upgrade:
https://www.toyota-4runner.org/4th-g...n-4runner.html
Very useful info, thanks for posting. Reviving and old thread but am just buying the parts for this upgrade and had a question. What exactly is the rear center at axle brake line for? Thank you!
Hoovey689
01-25-18 12:07 PM
maimou
GX - 1st Gen (2003-2009)
03-31-17 12:12 PM
GSing430
Suspension and Brakes
08-17-07 01:52 PM
yoshi
08-08-05 08:44 AM
CamRen
20
08-27-02 04:03 PM
Quick Reply: Will GX460 brake calipers fit on the GX470?
