DVD Override and Pictures!
Old 10-24-05 | 05:45 AM
  #106
pdantoni's Avatar
pdantoni
Default 2005 GX 470 DVD-NAV Operation
rsg,
On the 2005, it's the larger of the two end plugs. The one that is closest to the passenger seat. It is the only one that contains a voilet (purple) wire with a red stripe. This plug will also contain the LIGHT green wire.
Let me know if this helps.
Old 10-24-05 | 09:53 AM
  #107
nkostaki's Avatar
nkostaki
Smile Camera in GX470-Land Cruiser withut RSES
Hi everybody,
I'm barging in this thread but I'm nearing despair. I need to connect a rear parking camera to a Land Cruiser Prado (basically the exact same car, and how the GX470 is marketed out of the US/Canafa markets, uses the exact SatNav unit as the GX470). I am trying to find out if I can wire the camera straight onto the display or I need a "control" module by Lexus/Toyota to intervene.
All and any help will be very much appreciated
Old 10-25-05 | 12:19 AM
  #108
rgs's Avatar
rgs
pdantoni,
Thanks for the info.
I will try my second attempt this weekend and let you know how I did.
Old 10-29-05 | 04:49 PM
  #109
rgs's Avatar
rgs
Pdantoni,
It works!!! Just as you described. I didn't add the switch. I just cut both purple and green wires and grounded the green wire to the radio. It was pretty simple but I took it slowly since I am cutting wires of $50k vehicle. Check five times and cut once.
Thank you VERY MUCH!!!!!
Old 10-29-05 | 09:32 PM
  #110
ELEX470's Avatar
ELEX470
Default Need some help 05 GX470
What will happened if I will do this mode on my 2005 GX with NAV and Aftermarket entertainment center made by AUDIOVOX Model: PROV1021P?
Thank you
Old 10-30-05 | 01:24 AM
  #111
rgs's Avatar
rgs
Very likely .....nothing
Old 10-30-05 | 02:56 AM
  #112
Capirato's Avatar
Capirato
Default Nav - Tv
Thank you
For an aftermarket system you will need the following.
http://www.nav-tv.com/
~ Cap
Old 11-06-05 | 06:30 PM
  #113
cmc5dc's Avatar
cmc5dc
Well I have decided to tackle this mod but I would like to apply the switch as described in the beginning of this thread.....2003 Can some with experience detail where the 4 wires go on the switch ( double-pole, double-throw switch )which has 6 terminals on the back?
Thanks,
cmc
Old 11-08-05 | 04:14 PM
  #114
cmc5dc's Avatar
cmc5dc
anyone.....I know this thread is old but anyone w/ experience pls respond
Old 11-08-05 | 06:22 PM
  #115
jtbmoore's Avatar
jtbmoore
Forget the switch. It is a piece of cake. If you want to go back to the original configuration then just put it back together then.
Old 11-08-05 | 06:30 PM
  #116
Capirato's Avatar
Capirato
Default Switch
Problem is, without the Switch, you can't use the Navigation System at the same time.
~ Cao
Old 11-09-05 | 07:59 AM
  #117
jtbmoore's Avatar
jtbmoore
Sure you can. I did the mod and I switch back and forth all the time. Put the GX in park and pull the brake. Cycle through to the DVD player then switch over to NAV. This is how it will work while you are driving with the mod.
Old 11-09-05 | 08:20 AM
  #118
pdantoni's Avatar
pdantoni
I installed the switch on a 2005 GX 470.
FROM WHAT I REMEMBER....
1) By the time you are ready to install the switch, you will have cut the violet (purple) wire with the red stripe and the light green wire. By cutting these two wires you now have four cut ends.
2) The ends that run to the plug or the navigation screen go to the upper two poles.
3) The ends that run into the wiring harness go to the middle poles. Make sure the wire colors are aligned.
4) Run a wire to ground to the lower pole (Light Green wire side). The other pole on the lower side is not used.
Diagram:
Switch Poles
Violet Wire from Plug O O Light Green Wire from Plug
Violet Wife from Harness O O Light Green Wire from Harness
Blank O O Ground Wire
Throwing the switch up reconnects the original factory wires.
Throwing the switch down disconnects the violet wire and grounds the light green wire, allowing you to watch a DVD on the navigation screen.
Please let me know if this helps.
Philip
Old 11-09-05 | 08:32 AM
  #119
pdantoni's Avatar
pdantoni
My diagram in the previous post didn't come out to good. I'll try again.
Switch Poles ("O"):
------Violet Wire from Plug -----O O------Light Green Wire from Plug
Violet Wire from Harness------O O------Light Green Wire from Harness
---------------------------Blank -----O O------Ground Wire
Philip
Old 11-09-05 | 10:17 AM
  #120
loflin's Avatar
loflin
~ Cao
Cap, I haven't done it, but from all my reading in this long post, I believe this is incorrect. The wire that is cut (or switched) has nothing to do with the Nav function.
It is said the only reason for the switch is to put it back to exactly OEM function so in case you take it in and in case the Service guy was looking at issues in the system and kept seeing a Parking Brake ON signal or a lack of speed input to the DVD logic.
But, the Nav function is not affected in anyway.
If anyone knows for a fact this is incorrect please correct me.
