DVD Override and Pictures!
#122
Pdantoni,
Hey thanks for your input, your explanation/diagram was what I was looking for. I'll try the mod this weekend.
I have my car service from the dealership for oil changes and I did not want to void my warranty if they run a diagnostic test which they do and then your SOL.
Again thanks
cmc
Again thanks
cmc
#125
Originally Posted by pdantoni
My diagram in the previous post didn't come out to good. I'll try again.
Switch Poles ("O"):
------Violet Wire from Plug -----O O------Light Green Wire from Plug
Violet Wire from Harness------O O------Light Green Wire from Harness
---------------------------Blank -----O O------Ground Wire
Throwing the switch up reconnects the original factory wires.
Throwing the switch down disconnects the violet wire and grounds the light green wire, allowing you to watch a DVD on the navigation screen.
Please let me know if this helps.
Philip
Switch Poles ("O"):
Philip
I did as you described above, however something isn't wired right. Everything is normal as in stock but when I throw the switch up the brake light appears but dvd doesn't show up....if I hit audio button their is no bold picture button as in the case when the parking brake is up but like I said the parking light appears when I throw the switch up. Any suggestions?
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#126
Will this DVD Override fix for 2005 Gx470 will also allow me to use ALL the touchscreen functions while i am driving or i need to do something else?
if something else do you know what i need to do?
Thank you for your help!
#127
Originally Posted by cmc5dc
Phillip,
I did as you described above, however something isn't wired right. Everything is normal as in stock but when I throw the switch up the brake light appears but dvd doesn't show up....if I hit audio button their is no bold picture button as in the case when the parking brake is up but like I said the parking light appears when I throw the switch up. Any suggestions?![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#128
Originally Posted by loflin
Sounds like you have GND'd the wrong side of the Parking Brake signal. You need to GND the side going into the NAV, so it thinks the Prk Brake is on. You should NOT get the Pkg Brk light in the dash on, unless you've GND'd the part of the wire (you cut) that goes back up into the dash.
So the diagraph is correct and I just grnded the wrong side? If that is so than I'll try what you mentioned.
thanks,
cmc
#129
I'm not sure what's wrong. When I throw the switch, the brake light does not come on. Read the beginning of the this forum and check what the original post and pictures say. I diagram was from memory.
Sorry,
Philip
Sorry,
Philip
#130
Pardon any ignorance on my part but am I to understand that is you run the Violet wire with a red stripe of the NAV Computer through a switch, Open position to allow entry into the Nav screen and closed to resume normal operation. This is all that needs to be done for bypass on an 05 GX?
Thanks for any replies!
#131
Don't forget the emergency brake wire. In order to use the DVD on the front screen you have to disconnect the violet wire with the red stripe AND ground the light green wire. - Philip
#132
thanks,
cmc
thanks,
cmc
#133
Switch Poles ("O"):
Philip
Switch Poles ("O"):
Philip
My only question is when the switch is off shouldn't it act like stock.....pull the brake and hit the audio button then picture (on screen button) should appear in bold? It doesn't do it, the picture (on screen button) isn't bold but faint as in the inability to access while driving. Did I miss something
Any help/suggestions would be appreciated.
Newbie
