Gx470 Battery Drain fuse 44
Old 03-16-18, 09:14 PM
scott1010
scott1010's Avatar
Default Gx470 Battery Drain fuse 44
Hello.... Thanks in advance for your help
I own a Lexus 2005 Lexus GX470 with 140k miles.
Day 1 -Battery Dead / Car wont start
-Bought a new battery and installed it (never checked the old battery, just bought a new one since it was old)
Day 2 -Next morning the new battery was dead
-Put jumper cables on the car and drove it around for 1 hour. Battery tester said fully charged. (alternator works)
Day 3 -Next morning battery was dead again
(Took car to mechanic)
-Mechanic had the Lexus for 4 days and finally found the problem.
Problem: Fuse 44 (radio no.2 car audio system, navigation system)
When this fuse was pulled the battery held its charge overnight and started up just fine.
I have not put fuse 44 back into the box....My car now starts and drives great but I dont have a working radio, navigation, rear camera, cant control A/C or heater... who knows what else the LCD radio controls.
What should I do?
Take it to the Lexus dealership and pay a fortune so they can diagnose it?
Thanks again for your help....
Old 03-17-18, 06:11 AM
chiph9
chiph9's Avatar
Start eliminating things in that area by unplugging them one by one. So I'd start by removing the radio, then proceed from there.
If you have a clamp-on ammeter wait 15 minutes after closing the door before checking the reading to allow the body computer to go into an idle state.
Chip H.
Old 08-15-19, 08:53 PM
ChrisCol
ChrisCol's Avatar
I have the same thing, Scott with my 2008 RX400h. It was the fuse to the radio. Did you ever get an answer from Lexus? Sounds like a class action causing event.
Old 05-09-23, 04:54 PM
Kiki123
10th Gear
Kiki123's Avatar
I have the same issue with my 2004 GX 470. It has 216k miles. I pulled fuse 44 and the battery drain has stopped as well.
Old 06-02-23, 07:31 AM
speedtre
3rd Gear
speedtre's Avatar
Have you tracked this down yet...I've got the same issue.
Old 06-02-23, 06:48 PM
chiph9
chiph9's Avatar
It's likely to be different for everyone. There's no option but to follow the procedure of unplugging things one by one to see which one is causing the drain.
This video may help.
Chip H.
speedtre (06-22-23)
Old 06-05-23, 07:51 AM
Kiki123
10th Gear
Kiki123's Avatar
Yes, the radio had gone out, it was draining the battery. The problem with pulling fuse 44 is that this also controls the AC. I pulled the radio out and disconnected the wires to the radio then I put fuse 44 back and it works fine now. I don't use the radio and it's a work truck so I don't need that but you could replace the radio I guess...
Warning though... Its an old car so the clips that hold all the parts together on the dash, they're getting crispy and one or two just crumbled when I pulled the AC covers out in order to get to the radio. so be gentle or plan to manage that when you put the dash back on....
K
speedtre (06-22-23)
Old 06-22-23, 04:00 PM
speedtre
3rd Gear
speedtre's Avatar
K
So was your radio not working or was it working fine, but something in the radio was causing the drain. The radio on our GX470 works fine.
Old 08-18-23, 03:30 AM
RyanDalTX
4th Gear
RyanDalTX's Avatar
Default 03 Gx470 battery drain - popping noise on speakers with vehicle turned off
did you guys track down exactly what it is? My speakers are popping with the car turned off unless I disconnect battery. It’s rhythmic like tick, tick, tick, tick. I’m thinking about taking it to a car audio shop to see if a new radio solves the problem..thoughts?
radio works fine there has been intermittent crackling in speakers for a long time though. I don’t care about radio but definitely need AC control in texas summer
Old 08-18-23, 07:12 AM
Davenlei
Davenlei's Avatar
K
Wondering if it is not the radio but is the amp if you have the Mark Levinson system. There is a separate amp that powers the speakers and if that wigs out maybe it is not turning off.
Old 08-18-23, 07:42 AM
cacompz
10th Gear
cacompz's Avatar
This video might have a possible work around solution, by switching the radio constant power to accessory power instead.
You might lose some setting, but still able to use the a/c control since the display unit only has power when the car is running.
Old 08-18-23, 01:27 PM
RyanDalTX
4th Gear
RyanDalTX's Avatar
thanks for the input I’ll see if that’s what’s going on
Old 08-18-23, 05:18 PM
RyanDalTX
4th Gear
RyanDalTX's Avatar
I disconnected the amp and the popping from the speakers with the power turned off has stopped. I think we’ve found the problem. THANK YOU! Has anyone had success in replacing a factory amp at a stereo shop?
Old 08-20-23, 08:42 PM
Davenlei
Davenlei's Avatar
That amp is proprietary. Not sure about an aftermarket replacement and I know the used market is expensive. maybe time for a 'Tesla' style head unit replacement?
Old 08-21-23, 10:12 AM
RyanDalTX
4th Gear
RyanDalTX's Avatar
What is a Tesla style head unit replacement?
Quick Reply: Gx470 Battery Drain fuse 44
